Side mirror, 1971 |
Side mirror, 1971 |
milwlandrover |
Aug 26 2018, 03:40 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Both my '73 and '71 have crummy rubber adjustable side mirrors. what did the originals look like. I have seen pictures with round and rectangle and although both of my cars have (2) mirrors, I think the originals only had (1)
ConeDodger |
Aug 26 2018, 04:07 PM
Apex killer! Group: Members Posts: 23,553 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
All years look like this...
Passenger side mirrors were required in some markets and available in all I think. The door already has the threaded nut in place. Attached image(s) |
Aug 26 2018, 04:17 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Early mirror has a hard bend. Mid year and later has a softer curve
Attached thumbnail(s) |
ConeDodger |
Aug 26 2018, 04:36 PM
True, there were changes. But short of dumpster diving at the pick n pull or hanging out in the classified, you’ll only find late mirrors.
GaroldShaffer |
Aug 26 2018, 06:21 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
True, there were changes. But short of dumpster diving at the pick n pull or hanging out in the classified, you’ll only find late mirrors. Early mirror (IMG:style_emoticons/default/shades.gif) Attached image(s) |
Sep 7 2018, 12:42 PM
johnhora |
Sep 7 2018, 01:49 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
The mirror glass is also just slightly larger in the late style.
tmc914 |
Sep 7 2018, 06:32 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
While on the subject of mirrors...
My passenger side is like a magnifying glass. It is almost unusable. Most mirrors say "objects may be closer..." mine should say ..."Objects appear closer...". Are there two styles of mirror? |
Sep 7 2018, 07:00 PM
While on the subject of mirrors... My passenger side is like a magnifying glass. It is almost unusable. Most mirrors say "objects may be closer..." mine should say ..."Objects appear closer...". Are there two styles of mirror? You can always replace the glass with a regular piece. |
tmc914 |
Sep 7 2018, 07:02 PM
[/quote]
You can always replace the glass with a regular piece. [/quote] Did not think of that, will have to put on my to do list. Thanks. |
Sep 7 2018, 07:21 PM
[quote name='tmc914' date='Sep 7 2018, 09:02 PM' post='2646589']
[/quote] You can always replace the glass with a regular piece. [/quote] Did not think of that, will have to put on my to do list. Thanks. [/quote] 914rubber has both sizes of glass. If you decide to switch it out, don't use a flat blade screwdriver to remove the plastic ring. It damages the edge of the stainless steel but do lube up the spring and nut located behind the mirror, under the base and all the pivot points on the arm. |
Valy |
Sep 7 2018, 07:34 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
That is evidence of 21 murdered teeners! |
Sep 7 2018, 07:42 PM
That is evidence of 21 murdered teeners! Some give their lives so others might live. |
Larmo63 |
Sep 7 2018, 07:50 PM
marksteinhilber |
Sep 8 2018, 12:08 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Kaeferfreund |
Sep 18 2018, 02:02 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
@ mepstein
Is there some "interior" inside the mirror? Or just the glas and the plastic retaining ring/mirror gasket? Any differences between the early and the late style mirror interior? |
Sep 18 2018, 03:09 PM
@ mepstein Is there some "interior" inside the mirror? Or just the glas and the plastic retaining ring/mirror gasket? Any differences between the early and the late style mirror interior? Yes, the interior gaskets that hold the glass are different. I don't have them in front of me now but I'm sure there are pics online. You do need the interior gasket/spacer or the glass will rattle. |
Sep 18 2018, 07:38 PM
There's a thread around here that shows the inside of the mirror. It's the metal case, a clear-ish soft plastic spacer, the glass, and the black retaining ring. The thread might be in the Parts Vault forum?
--DD |
FlacaProductions |
Sep 18 2018, 07:51 PM
Senior Member Group: Members Posts: 1,550 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Passenger and drivers mirror are the same, correct? Just one part number?
Sep 18 2018, 07:58 PM
Passenger and drivers mirror are the same, correct? Just one part number? There was a different passenger mirror with a curved lens (that not everyone likes). 99% just take a driver side and flip it. If you buy a used mirror, don't force it to move at the joints. They are often dry and corroded. Try dripping some light lube to see if you can get it moving again. If it won't move easily, take the mirror apart, clean and lube all the hardware. I have 20 mirrors and half of them have a little bulge at the back of the mirror because too much pressure was used to adjust the mirror. |
Lo-Fi Version | Time is now: 20th April 2024 - 07:38 AM |
