LED headlight bulb install, Vintage Car LED VC 4000 |
gereed75 |
Aug 26 2018, 07:11 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
These lights are the second to highest in their product line. Chose them because they are preassembled into an H4 lens and do not use a fan.
This started as a 1 hour project that as usual turned into a 4 hour thing. After fighting nearly 50 year old screws the biggest issue became where to mount the circuit board box that is part of the assembly. First impression is it should be easy, but there is really not that much room in the headlight bucket as the assembly rotates up and down and the placement is not inconsequential. Not inconsequential because one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car. At any rate, I ended up wrap tying onto the bracket that holds the spring. This position is a good fit. and remains out of the way as the assembly moves through its motion. Pix below. Maybe this will save someone else some time (and a cracked plastic trim bucket). Warning: Many wrap ties died in the completion of this project. Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!! Attached thumbnail(s) Attached image(s) |
Cairo94507 |
May 13 2021, 12:11 PM
Michael Group: Members Posts: 9,734 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I just received a set of these lights. I will tackle this project soon and take some pictures as well. I suspect finding a suitable location to secure the power module will be the biggest issue. Stay tuned and a special thanks to @gereed75 for taking the time to post about this exact issue and take and post pictures.
Cheers, Michael (IMG:style_emoticons/default/beer3.gif) |
JeffBowlsby |
May 13 2021, 12:16 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Any issues with your hi/lo beam selector relay after the install?
Cairo94507 |
May 13 2021, 12:41 PM
Hi Jeff,
I actually plugged mine in just to test that exact issue and they seemed to work with no issues at all. On/off, hi/low, etc. Michael |
horizontally-opposed |
May 13 2021, 12:44 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
…one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car. Maybe this will save someone else some time (and a cracked plastic trim bucket). Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!! Sorry to hear one of your 914's original parts was damaged. Thank you for letting us know your take on the performance with LEDs in H4 housings, as I've been weighing whether to add LEDa to my H4s. Bought these, but apparently managed to order the 5.75s and had to return them > wait for the 7s. https://vintagecarleds.com/shop/7-inch/vcm3...-headlight-kit/ Another long lead time got me to wondering if the bulbs or housings are unique to the company. Eventually, I found these For $29, curiosity got the better of me and they were delivered before the replacement 7-inch H4 units were. They sure looked like the same bulbs to me, so I returned the 7-inch units. I have yet to try the bulbs, as there's a lot of conflicting info out there re: LED bulbs in H4 housings. Also need to find some garage time, which is rarer than I'd like! |
Cairo94507 |
May 16 2021, 03:57 PM
OK, so I tacked this today after reviewing @gereed75 pictures and posting. Very simple after that. Love that these lights look perfectly correct for the car.
Now I need to get a hold of Kent and see if he can re-adjust the eyebrows, etc. so the shut lines are prefect. Kent had to mess with the eyebrows and headlight doors when the other set of LED headlights were in the car as the stuck out about 3/8" beyond the bezel. Oh, you can make fun of my driving lights. Mine are at Jerry's (Spokes) getting his new circular LEDs installed. I can't wait to get them back. I covered the buckets with tin foil 'cause I am weird like that. Anyway here are some pictures: Attached thumbnail(s) |
dr.tim |
May 16 2021, 04:17 PM
Member Group: Members Posts: 101 Joined: 17-December 11 From: Butte, America Member No.: 13,907 Region Association: Rocky Mountains |
Nice!
I've been looking for a good 5.75 option for the other hobby-car. |
May 16 2021, 06:25 PM
OK, so I tacked this today after reviewing @gereed75 pictures and posting. Very simple after that. Love that these lights look perfectly correct for the car. Now I need to get a hold of Kent and see if he can re-adjust the eyebrows, etc. so the shut lines are prefect. Kent had to mess with the eyebrows and headlight doors when the other set of LED headlights were in the car as the stuck out about 3/8" beyond the bezel. Oh, you can make fun of my driving lights. Mine are at Jerry's (Spokes) getting his new circular LEDs installed. I can't wait to get them back. I covered the buckets with tin foil 'cause I am weird like that. Anyway here are some pictures: Fit looks good, and your car's overall fit and finish continue to slay me. And you say you want to make it better? (IMG:style_emoticons/default/unsure.gif) Very curious to hear your feedback on performance! |
Montreal914 |
May 16 2021, 07:18 PM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Eventually, I found these For $29, curiosity got the better of me and they were delivered before the replacement 7-inch H4 units were. They sure looked like the same bulbs to me, so I returned the 7-inch units. I have yet to try the bulbs, as there's a lot of conflicting info out there re: LED bulbs in H4 housings. Also need to find some garage time, which is rarer than I'd like! Looking forward to reading your review. That is definitely a sweet deal when you already have the H4 globe. (IMG:style_emoticons/default/smilie_pokal.gif) |
Cairo94507 |
May 16 2021, 09:35 PM
@horizontally-opposed Thanks for the compliments. I may get up early and take it for a spin in the dark to see how the lights perform. I will let you know.
To get the GE Nighthawks to fit the eyebrows had to be adjusted as did the headlight doors. Now with the H4 Hella lights fitting as they should, I need to get Kent to adjust the eye brows, etc so the headlight assemblies match the shut lines of everything else. I do love the car and it is running great. The more I drive it the more I realize what an absolutely stunning job Kent, Jim, Andy and Bob did. (IMG:style_emoticons/default/beerchug.gif) |
gereed75 |
May 17 2021, 06:42 AM
Looking good mike. Glad to hear that the location of the circuit box worked out for you also. Sorta confirms that it is a good place.
I did have to make the wire grounding mod to the light relay to restore normal function to my fog lights. No big deal, just find the thread and do it. Glad to have contributed to your stunning car in a very small way. You will love the performance of these lights and retention of the classic H4 look. Drive safe |
Cairo94507 |
May 17 2021, 05:52 PM
@horizontally-opposed So I got a chance to drive with these at 0500 today. They throw some great light. I would say they are at least as bright as the GE Nighthawks and may even be brighter. I did note they were a bit high so I will adjust them down. I do not want to offend on-coming drivers. (IMG:style_emoticons/default/sunglasses.gif)
@gereed75 Thanks so much for the help with this project. These lights look perfect in the car. I had them in my last 6, 30 years ago, but that was when you still had to run the 80/100 bulbs and a relay. Even then, they did not light like these. (IMG:style_emoticons/default/beerchug.gif) |
May 17 2021, 09:02 PM
@horizontally-opposed So I got a chance to drive with these at 0500 today. They throw some great light. I would say they are at least as bright as the GE Nighthawks and may even be brighter. I did note they were a bit high so I will adjust them down. I do not want to offend on-coming drivers. (IMG:style_emoticons/default/sunglasses.gif) @gereed75 Thanks so much for the help with this project. These lights look perfect in the car. I had them in my last 6, 30 years ago, but that was when you still had to run the 80/100 bulbs and a relay. Even then, they did not light like these. (IMG:style_emoticons/default/beerchug.gif) Fantastic news, better than 80/100s without the draw? May need to get these in sooner than later! I guess that really only leaves the question about how they affect oncoming drivers. Not sure how to test that, other than to see how many people start flashing you? |
Cairo94507 |
May 17 2021, 09:05 PM
The jury may be out for quite some time on that issue as I rarely drive the car at night. I am going to try to (IMG:style_emoticons/default/beer3.gif) get down to LA soon, so that would be the first real test.
DC_neun_vierzehn |
May 17 2021, 09:25 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Thanks for sharing this info.
I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company? https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ |
Cairo94507 |
May 18 2021, 06:56 AM
@DC_nuen_vierzehn I am not sure but the H4 headlights look to be no different than any other H4 I have seen. (IMG:style_emoticons/default/beerchug.gif)
anderssj |
May 18 2021, 09:51 AM
Dog is my copilot... Group: Members Posts: 1,654 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Thanks for sharing this info. I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company? https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ I've got the same question...914 currently has a pair of SEV Marchal flat-faced H4s and would love to keep them. But first I need to do Spoke's LED rear signal lights! |
gereed75 |
May 18 2021, 10:29 AM
I suspect they drop in to “standard” H4’s. Do not think Vintagecarleds has special H4’s made just for them, but...
Just ask them, they are domestic and responsive Not sure about the oncoming driver issue, I can only tell you that the low beam cutoff is very distinct and when projected on a wall is very low and very distinct. |
DC_neun_vierzehn |
Jun 1 2021, 10:11 AM
I suspect they drop in to “standard” H4’s. Do not think Vintagecarleds has special H4’s made just for them, but... Just ask them, they are domestic and responsive Not sure about the oncoming driver issue, I can only tell you that the low beam cutoff is very distinct and when projected on a wall is very low and very distinct. I shot them a message. Will share their response. |
DC_neun_vierzehn |
Jun 2 2021, 04:48 PM
Thanks for sharing this info. I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company? https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ I heard back from them ... they are a direct fit for Hella H4 globes. I placed an order. Will share the results after I install them. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:59 PM |
