LED headlight bulb install, Vintage Car LED VC 4000 |
gereed75 |
Aug 26 2018, 07:11 PM
Senior Member Group: Members Posts: 1,247 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
These lights are the second to highest in their product line. Chose them because they are preassembled into an H4 lens and do not use a fan.
This started as a 1 hour project that as usual turned into a 4 hour thing. After fighting nearly 50 year old screws the biggest issue became where to mount the circuit board box that is part of the assembly. First impression is it should be easy, but there is really not that much room in the headlight bucket as the assembly rotates up and down and the placement is not inconsequential. Not inconsequential because one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car. At any rate, I ended up wrap tying onto the bracket that holds the spring. This position is a good fit. and remains out of the way as the assembly moves through its motion. Pix below. Maybe this will save someone else some time (and a cracked plastic trim bucket). Warning: Many wrap ties died in the completion of this project. Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!! Attached thumbnail(s) Attached image(s) |
DC_neun_vierzehn |
May 17 2021, 09:25 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Thanks for sharing this info.
I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company? https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ |
anderssj |
May 18 2021, 09:51 AM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Thanks for sharing this info. I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company? https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ I've got the same question...914 currently has a pair of SEV Marchal flat-faced H4s and would love to keep them. But first I need to do Spoke's LED rear signal lights! |
Lo-Fi Version | Time is now: 19th May 2024 - 08:54 AM |
