Top Restoration |
Top Restoration |
EdwardBlume |
Sep 3 2018, 02:32 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
The ABM needs a new top. The prior one I had restored is early vs late. This time I’m going to do it myself.
I picked up a late top at the swap yesterday. What are the 4 stages and products from wheeler dealer? I need to paint it for sure due to aging, scratches, dings and chips. Also, what is this seal on the rear inside. It is chalky and old. Needs replacement. Attached thumbnail(s) |
914 RZ-1 |
Sep 15 2018, 02:26 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
FWIW, I restored my top as follows:
1. I took all the hardware off and sanded it down. Used a DA and electric sander in combination. I used industrial strength adhesive remover (3M 38987) to get the glue off from the headliner. I also sanded that side. 2. I accidentally sanded thru the fiberglass gel coat in one spot, so I got some polyester primer surfacer and a cheap Harbor Freight gun and sprayed the top with it. Turned out really nice. 3. I then sprayed the Wurth Stone Guard Black. Used about 3 cans. I did the whole thing, top and underside. I'm not putting the carpet back on the underside. I did a few practice sprays on some scrap to get a feel for what it should look like. 4. I then sprayed Trim Black (from my local autobody supply place) with the same HF spray gun. 5. I have all new rubber from 914rubber. I also cleaned up all the latches and screws with a wire brush and Evapo-Rust. I painted them with Trim Black. The plastic parts were in decent shape. Looks bichin'. My top did not rub the trunk lid before I restored it. |
Lo-Fi Version | Time is now: 12th May 2024 - 08:34 PM |
