FS 914 race/street car $17,000 usd, 1971 2165cc Type 4 |
jacquot |
Sep 3 2018, 03:35 PM
Member Group: Members Posts: 59 Joined: 12-March 15 From: Huntington Beach / Paris Member No.: 18,512 Region Association: Southern California |
1971 Porsche 914-4, street licensed, clear CA title, suitable for track.
Car is available for inspection in Palm Desert, CA Questions, please email: lakejacquot@yahoo.com Car was purchased in early 1990’s for autocross, then time-trialed and raced primarily with POC in the mid-late 1990’s as a stock 1.7L. In the late 1990’s and early 2000’s it was time-trialed and raced in current configuration with POC and on occasion PCA. It has been primarily a street car since mid 2000’s. Car was stored indoors and not driven for a few years early 2010’s but has been driven weekly since approximately 2014 and always stored indoors with few exceptions. Black paint is original color, resprayed once that we know of and has expected dings and chips from wheel to wheel racing (not always at the front). Spare frunk and trunk lids and top are on car in blue color. Only known body damage (minor) to right front fender and driver door. Paint looks better from a distance and in photos. Doors and door windows are not original (late version) but function as intended. Windshield is new. Dash cover has been removed as have carpets and back pad. Longitudinals, rear wheel wells and trailing arms have been reinforced. A couple of repairs were completed with fiberglass in the 1990’s including hell hole and frunk floor behind oil cooler. Available most days in Palm Desert, CA. Please email questions. 2165 cc Type 4 Porsche engine by Precision Motorwerks, BRD 1998 Porsche 2.0L heads JE pistons, 94mm Scat forged crankshaft 78 x 2.0 Carillo Rods Fat Performance stainless steel valves 44 x 38 Fat Performance FC443 Camshaft .507 lift, 290 dur Fat Performance cam gear, followers, retainers Fat Performance dual valve springs Fat Performance cam followers Fat Performance CS 780 shroud / Porsche 911, 11 blade fan Porsche Carrera alternator lightened flywheel Weber 44idf Carburetors Carter fuel pump Crane XR700 electronic ignition Bosch 009 distributor 914-6 oil tank Front mounted Mazda oil cooler Dash 12 Aeroquip oil lines and connectors Auxillary oil dry sump pump Porsche 911 ss front suspension / Boge inserts / m calipers / Porterfield pads Porsche 911 19 mm front torsion bars Tarrett Engineering TFS-22 front swaybar and drop links 5 lug rear / Porsche 911 sc calipers / Porterfield pads / no ebrake Porsche 914, 19 mm OE rear stabiliser 180# rear springs Porsche 19 mm brake master cylinder Porsche type 901 side shift transmission ATS cookie cutters cast aluminum wheels 7J x 15 Dunlop Direzza DZ102 tires 205/50/R15 v86 Battery in rear trunk Fuel Safe ProCell bladder in 914 OE tank Safety Devices FIA 914 Steel Cage Safecraft Fire Protection System (Fuel Tank, Driver Compartment, Engine Compartment) Driver's seat from OE with extended bolsters and adaptation for five-point belts driver and passenger. Included spare parts are 4 cookie cutter wheels, frunk and trunk lids also top (all 3 are blue) wing, fog light pieces, various gauges and other hard parts. Other spares may be available. I believe all information and specifications to be accurate Attached image(s) |
2mAn |
Sep 18 2018, 10:47 PM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
what group does this qualify for with the bigger 4?
jacquot |
Sep 24 2018, 01:17 PM
A bit slow on reply as I've been exploring CA & NV deserts.
However, I / we ran V5 with POC. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:05 AM |
