I got a welder!, Harbor Freight had a big sale today! |
bmtrnavsky |
Sep 3 2018, 05:56 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
Look what I got today! It’s not the best witefeed welder on the market but dang it is better than what I had which was no welder! I’m pretty excited because now I have 100 new things I can do! (IMG:style_emoticons/default/piratenanner.gif)
Attached thumbnail(s) |
Spoke |
Sep 5 2018, 06:00 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Good luck with your welder. I bought mine several years ago and the first day I fixed 3 broken and cracked items on my 914. It was so cool to fix things properly by welding them that I stood there looking around to other things I could weld.
My unit is a 110V Millermatic 135. I thought about getting a 220V unit and glad I bought the 110V one. I have outlets all around my garage and it's convenient to move the welder around to the closest outlet. Chances are most welding done on a 914 can be done with a 110V unit. |
mepstein |
Sep 5 2018, 06:42 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Good luck with your welder. I bought mine several years ago and the first day I fixed 3 broken and cracked items on my 914. It was so cool to fix things properly by welding them that I stood there looking around to other things I could weld. My unit is a 110V Millermatic 135. I thought about getting a 220V unit and glad I bought the 110V one. I have outlets all around my garage and it's convenient to move the welder around to the closest outlet. Chances are most welding done on a 914 can be done with a 110V unit. I got the Hobart mvp. Does both 110 and 220. I didn’t want to be tethered to 220 but wanted to have able to weld up some heavier steel if I felt the need. Now I’m buying safety equipment and basic tools. |
bmtrnavsky |
Sep 14 2018, 09:06 AM
Good luck with your welder. I bought mine several years ago and the first day I fixed 3 broken and cracked items on my 914. It was so cool to fix things properly by welding them that I stood there looking around to other things I could weld. My unit is a 110V Millermatic 135. I thought about getting a 220V unit and glad I bought the 110V one. I have outlets all around my garage and it's convenient to move the welder around to the closest outlet. Chances are most welding done on a 914 can be done with a 110V unit. I got the Hobart mvp. Does both 110 and 220. I didn’t want to be tethered to 220 but wanted to have able to weld up some heavier steel if I felt the need. Now I’m buying safety equipment and basic tools. That's awesome. I'm so busy this time of year I STILL haven't welded anything. I have 5 kids... yes that's right 5! so fall is crazy with football, band, and twirl plus my job. its also hot in Texas, but it's getting to good garage weather so I'm excited. I'm buying some angle iron to build a stand for my grinder and drill press so my first project is on its way! I discovered the joy of the scrap yard this week and bought a small piece of plate steel to put under my vice. I also got a couple pieces of flat bar. I'll be trying to go back soon to get some copper pipe to plumb in my airlines and also the rest of the angle iron I need for that table and a leaf spring to make a slapping spoon. (IMG:style_emoticons/default/piratenanner.gif) |
John90290 |
Sep 14 2018, 07:00 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Congratulations! You wil now never go by a garage sale or drive by a bunch of furniture on the side of the road without looking for bed frames! I had one of those years ago then went to a Hobart 140 and added gas. Still not a good welder but got good at grinding;) A few pro welders I knew told me that the HF welder was a good place to start but don’t use the wire it came with. Head to Home Depot and get a roll of the Lincoln flux core wire. Try both and you will see the difference.
Best of luck. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:20 PM |
