swapping engines someday, Whats the weight difference |
Jetsetsurfshop |
Sep 4 2018, 07:08 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey race fans,
Sometime in the future I plan on running a 2.7 six over my four banger. Anyone have any idea about where my weight will be after the -6? I'm I looking at 50lbs? 100lbs? More?? I could drop some weight from the car still. Want to get that HP to weight just right!! Theres a large group in NASA (ST4) I think I could fit into perfectly If I get the math correct. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/driving.gif) |
campbellcj |
Oct 28 2018, 08:19 AM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
My car was 1995lbs wet, last time on the POC scales. That is with full race safety equipment including a passenger seat + harness. Mag case 2.7 with extensive machine work and race mods; modded mag 914 sideshift trans. 235rwhp.
As noted, the -6 engines are frighteningly expensive to have someone build/rebuild these days. Someday I may try to do one myself. Have dreamt about a short-stroke 2.5 or a full tilt 2.8 or 3.0RSR with MFI. But even the decent cores are getting spendy. |
Jetsetsurfshop |
Nov 5 2018, 01:17 PM
My car was 1995lbs wet, last time on the POC scales. That is with full race safety equipment including a passenger seat + harness. Mag case 2.7 with extensive machine work and race mods; modded mag 914 sideshift trans. 235rwhp. As noted, the -6 engines are frighteningly expensive to have someone build/rebuild these days. Someday I may try to do one myself. Have dreamt about a short-stroke 2.5 or a full tilt 2.8 or 3.0RSR with MFI. But even the decent cores are getting spendy. Hey Chris, I love 235rwhp. Pretty awesome. (IMG:style_emoticons/default/beerchug.gif) When you say "extensive machine work" Are you talking about shuffle pins and boat tailing? My case is at the machine shop now, having a hard time deciding to spend that extra change? Shane (IMG:style_emoticons/default/driving.gif) |
campbellcj |
Nov 22 2018, 09:05 AM
Hey Chris, I love 235rwhp. Pretty awesome. (IMG:style_emoticons/default/beerchug.gif) When you say "extensive machine work" Are you talking about shuffle pins and boat tailing? My case is at the machine shop now, having a hard time deciding to spend that extra change? Shane (IMG:style_emoticons/default/driving.gif) So I finally looked-up my engine build notes and both cases I have seem to have similar machining: - Case savers - Time certs - Oil bypass mod(s) - Full-groove/enlarge #4 main bearing - Surface spigots - Screw-in galley plugs - Line bored Std/Std The spare also has Shuffle Pins. The machine work on this spare case was ~1500 around 5 years ago. I got a great deal on the case already-done when somebody changed their build plans. Two other important factors I remember is we used ARP studs/hardware and a 930 (IIRC) oil pump. The first 2.7 I bought already-built (which failed pretty quickly) had a 964 pump which apparently is not as robust. I think the GT3 pump is also popular for hotrod builds. The current engine is set up for top-end power, here is a dyno sheet - Attached File(s) 914R_Dyno_sheet_2017_02_12.pdf ( 794.39k ) Number of downloads: 56 |
mepstein |
Nov 22 2018, 09:32 AM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Hey Chris, I love 235rwhp. Pretty awesome. (IMG:style_emoticons/default/beerchug.gif) When you say "extensive machine work" Are you talking about shuffle pins and boat tailing? My case is at the machine shop now, having a hard time deciding to spend that extra change? Shane (IMG:style_emoticons/default/driving.gif) So I finally looked-up my engine build notes and both cases I have seem to have similar machining: - Case savers - Time certs - Oil bypass mod(s) - Full-groove/enlarge #4 main bearing - Surface spigots - Screw-in galley plugs - Line bored Std/Std The spare also has Shuffle Pins. The machine work on this spare case was ~1500 around 5 years ago. I got a great deal on the case already-done when somebody changed their build plans. Two other important factors I remember is we used ARP studs/hardware and a 930 (IIRC) oil pump. The first 2.7 I bought already-built (which failed pretty quickly) had a 964 pump which apparently is not as robust. I think the GT3 pump is also popular for hotrod builds. The current engine is set up for top-end power, here is a dyno sheet - We just built a 3.0 for the track with a gt3 pump. I think the pump was around $900. |
Lo-Fi Version | Time is now: 11th May 2024 - 09:03 PM |
