Shifting Issues after Side Shift Conversion |
914bub |
Sep 8 2018, 08:21 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I collected parts for 3 years for my conversion and finally completed it this week. Now the shifter is super stiff to move anywhere. Here's a little background info:
I installed a side shift transmission and of course converted, shifter, linkage etc. New bushing back at the transmission and a Tangerine bushing at the firewall,(Thanks Chris!) I have only backed it out of the garage, turned it around and backed it back in so I haven't had it on the road to row through the gears. What concerns me is I've had issues before finding gears,(one of the reasons I converted, but not the only one), but now it is very stiff even moving side to side in what is neutral. You know how you can grab your shifter and "wiggle" it side to side without moving it forward or back to select a gear? even moving it there is stiff. It's like something is binding? A little more info. I installed a new complete clutch kit with new flywheel about 1000 miles ago. New clutch cable with the side shift conversion and I also inspected clutch tube in tunnel to be sure it was OK but I know that won't cause shift linkage binding. Pedal assembly is freshly rebuilt as well. I'm just trying to give as much clutch/transmission/shifter info as I can! Any ideas? I've waited four years for first gear and haven't driven the car in 2 years now. While it was down I also installed the stereo, ATS classics with new Michelins, fuel pump conversion and few more things. As you can imagine I'm itchy to try it all out! Any help would be greatly appreciated! |
914bub |
Sep 8 2018, 11:02 PM
THANK You for all the responses! I love 914world! I haven't gone back to look as I just got back from being called into work on overtime but I appreciate how everybody responded so quickly. I'm going to look at it tomorrow and I'll update the thread.
Thanks again, "the world" rocks,.......AGAIN! @porschetub I got the trans from a friend who's sons car was wrecked. The trans worked flawlessly before the crash and the crash wasn't severe enough to wreck the trans. I super appreciate all the responses. Keep 'em coming, please. |
914bub |
Oct 13 2018, 11:58 PM
So another update and plea for opinions.I checked the seatbelt bolt and NO issue there. I had a roll pin in my shifter coupling that I had to remove to replace coupler bushings. I got the roll pin out and replaced the shifter bushings at the coupler. The holes in the coupler are slightly ovaled but the bushings went in OK and don't have any play.I had our machinist at work shave the front of the coupler to ensure I had enough room for forward and aft movement with the tangerine conversion bushing installed.
I went to replace the bushing at the shift console and the hole in the console is enlarged so the new bushing, (914rubber), "floats" in the hole, it is installed in. I now have reverse, First (finally,.....thank you Jesus), second, third, and fifth gears. I have another shift console that I "rebuilt", new seal cleaned shaft etc. It still has the old shift bushing from my core transmission but seems tight so I'll transfer the new one I got from Mark. I've been working hard to get any slop out of the shift linkage that I can. Might the shift console bushing cause me to not get fourth gear? I adjusted the shifter via the shifter-right armrest bungee method. Is it potentially a little more adjustment needed? I'm so over this issue. I've waited for shift improvements for 4 years now! If I don't get through this soon it'll be listed in the classifieds in the "rolled off a cliff and burned" section. Any help,as always, is appreciated. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:19 PM |
