Set of five Fuchs 2.0 Restored by All Reed (MINT) SOLD! |
pete000 |
Sep 9 2018, 10:40 PM
I am selling my perfect set of five factory Fuchs 2.0 wheels. These were restored by All Reed to perfection.
Five factory Fuchs 2.0 wheels fully restored by Al Reed (MINT) Four Alloy ISP center caps Four 5mm wheel spacers Two Tangerine Racing Hub centric rear adapters. Factory valve stems. 16 factory 2.0 lug bolts recently re plated with the correct silver zinc plating. Wheels all date stamped 4/73,11/73,12/73,12/73,12/73 Will sell all for $1800.00 plus shipping. This is the perfect setup for the narrow body 914. Note: That is copper anti seize on the lugs... Attached thumbnail(s) |
914_7T3 |
Sep 9 2018, 10:54 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
What are the date codes and are they all the same?
pete000 |
Sep 9 2018, 11:59 PM
I will verify the date codes shortly...
Sep 10 2018, 05:22 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Great price. Cost that much do get it done now.
amfab |
Sep 10 2018, 11:56 AM
Member Group: Members Posts: 391 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
OT but, man that car looks clean. Door gaps look perfect
pete000 |
Sep 10 2018, 11:39 PM
I would rate these wheels a 9.98 out of 10
orthobiz |
Sep 12 2018, 09:55 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Lug bolts??
Paul |
orthobiz |
Sep 12 2018, 09:56 AM
designerguy90 |
Sep 12 2018, 11:34 AM
Member Group: Members Posts: 52 Joined: 21-July 14 From: Chicagoland Member No.: 17,666 Region Association: None |
PM Sent
914_teener |
Sep 12 2018, 02:14 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'll be second in line Pete if it falls through.
Rob |
pete000 |
Sep 12 2018, 02:40 PM
Going in order of responses, if first passes this weekend goes to second, etc...Thanks for the kind comments, this car is a gem.
914_7T3 |
Sep 12 2018, 02:56 PM
Going in order of responses, if first passes this weekend goes to second, etc...Thanks for the kind comments, this car is a gem. Pete, Not sure if you were considering me in the order of interested parties, but I'll speed up the process by taking a pass. I decided to restore my original set that is date coded to the same month as the production of the car. Nice car BTW and hope to see you on Sunday (IMG:style_emoticons/default/beerchug.gif) |
pete000 |
Oct 3 2018, 06:06 PM
Update on the wheels, they are good to go with all tires now dismounted. I am now including the following.
Five factory Fuchs 2.0 wheels fully restored by Al Reed (MINT) Four Alloy ISP center caps Four 5mm wheel spacers Two Tangerine Racing Hub centric rear adapters. Factory valve stems. 16 factory 2.0 lug bolts recently re plated with the correct silver zinc plating. Wheels all date stamped 4/73,11/73,12/73,12/73,12/73 Will sell all for $1800.00 plus shipping. This is the perfect setup for the narrow body 914. Attached thumbnail(s) Attached image(s) |
pete000 |
Oct 5 2018, 07:51 PM
SOLD,Thanks!
AMac |
Oct 16 2018, 07:17 PM
Newbie Group: Members Posts: 6 Joined: 9-May 18 From: North Vancouver Member No.: 22,106 Region Association: Canada |
I am selling my perfect set of five factory Fuchs 2.0 wheels. These were restored by All Reed to perfection. Five factory Fuchs 2.0 wheels fully restored by Al Reed (MINT) Four Alloy ISP center caps Four 5mm wheel spacers Two Tangerine Racing Hub centric rear adapters. Factory valve stems. 16 factory 2.0 lug bolts recently re plated with the correct silver zinc plating. Wheels all date stamped 4/73,11/73,12/73,12/73,12/73 Will sell all for $1800.00 plus shipping. This is the perfect setup for the narrow body 914. Note: That is copper anti seize on the lugs... Hi, Im looking for wheel spacers, where did you find the 5mm 4 bolt? I agree 5mm makes most sense. My wheels, 2.0 such, are refinished ready to go back on. Thanks Cheers, Andrew |
Oct 16 2018, 07:32 PM
I am selling my perfect set of five factory Fuchs 2.0 wheels. These were restored by All Reed to perfection. Five factory Fuchs 2.0 wheels fully restored by Al Reed (MINT) Four Alloy ISP center caps Four 5mm wheel spacers Two Tangerine Racing Hub centric rear adapters. Factory valve stems. 16 factory 2.0 lug bolts recently re plated with the correct silver zinc plating. Wheels all date stamped 4/73,11/73,12/73,12/73,12/73 Will sell all for $1800.00 plus shipping. This is the perfect setup for the narrow body 914. Note: That is copper anti seize on the lugs... Hi, Im looking for wheel spacers, where did you find the 5mm 4 bolt? I agree 5mm makes most sense. My wheels, 2.0 such, are refinished ready to go back on. Thanks Cheers, Andrew amazon has them https://www.amazon.com/4x100-Hubcentric-57-...t+wheel+spacers |
pete000 |
Oct 16 2018, 11:00 PM
To be honest I can't remember where i got them, but they seem to be readily available. 5mm is the max you can run on the 2.0 wheel bolts.
jos.hall |
Oct 17 2018, 01:10 AM
Newbie Group: Members Posts: 35 Joined: 5-June 15 From: Menifee CA Member No.: 18,804 Region Association: None |
make sure you order the 4x130 and not the 4x100 in the Amazon link.
Lo-Fi Version | Time is now: 23rd April 2024 - 12:18 AM |
