Emergency Brake adjust problem, On the inside is a cap, does it hold hydraulic pressure ?? |
barefoot |
Sep 10 2018, 09:57 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
After cleaning & repainting by rear calipers I find that the cap covering the inside adjusting guts is stripped in the hex bore for the hex wrench.
I was able to get it loose with the old chisel technique but no way can I torque it back in after doing the inner adjustment. If that cap has to hold hydraulic brake pressure then i'm screwed as no way to torque it back in. If it's just a dust cap, i can use a vinyl plug Comments from those who know ?? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:48 PM |
