WTB - Metal Clutch Cable Pulley, Mine Keep Melting |
motorvated |
Sep 10 2018, 07:02 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Switched over to a header/megaphone exhaust and quickly melted the stock white plastic pulley on the transaxle. Wrapped the headers and collector with fiberglass tape and installed a black delrin pulley, and promptly melted that one too. The collector sits very close to the pulley. I'm racing the car so things are getting pretty hot under there. Anyone have or know where I can get a metal pulley. I know that some were produced a while back, so if you have one in your parts stash that you won't be using, I could certainly use it. Thanks, Mike.
1adam12 |
Sep 10 2018, 11:01 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
You may want to look into some heat deflector sheets in the meantime. Either DEI or DCI will have some heat reflective material with adhesive backing that you could custom form to the back housing of the cable pulley housing and then use a heavy duty formable reflective sheet on the face exposed to the headers like a cover. You'll have to tin cut it to shape and then use safety wire to attach. Not the prettiest solution but could get the job done until you find an aluminum pulley wheel.
Lo-Fi Version | Time is now: 24th April 2024 - 04:34 PM |
