WTB - Metal Clutch Cable Pulley, Mine Keep Melting |
motorvated |
Sep 10 2018, 07:02 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Switched over to a header/megaphone exhaust and quickly melted the stock white plastic pulley on the transaxle. Wrapped the headers and collector with fiberglass tape and installed a black delrin pulley, and promptly melted that one too. The collector sits very close to the pulley. I'm racing the car so things are getting pretty hot under there. Anyone have or know where I can get a metal pulley. I know that some were produced a while back, so if you have one in your parts stash that you won't be using, I could certainly use it. Thanks, Mike.
JamesM |
Sep 13 2018, 05:24 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Are you sure there is not something else going on with the tune of your car? That seems like a lot of heat in your exhaust.
Running a similar setup on my autocross car with the 4-1 collector running right by the clutch pulley. Prior to jet-hot coating and a custom bracket to angle the clutch cable slightly lower, the best I was able to do was melt the cable sheath where it ran close to the pipes. Melting the pulley that is not in direct contact with the exhaust just seems like a crazy amount of heat. Retarded timing can cause some really high EGTs, just saying. |
Lo-Fi Version | Time is now: 26th April 2024 - 03:29 PM |
