> Early 914 brake light switch
isdyl
post Sep 11 2018, 02:08 AM
Region Association: England
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
isdyl
post Sep 11 2018, 11:51 AM
Ah yes! Brilliant - thanks - this forum is excellent. I have just dug around under the peddles and seen the other switch. You have saved me a load of bother trying to get that 2 pole switch.
I actually wrote to Bosch last week saying I couldn't locate a 2 pole version and could I use a 0343102010. They couldn't have been less helpful - I'm actually quite annoyed by their 'couldn't care less' replies!
ClayPerrine
post Sep 11 2018, 02:55 PM
QUOTE(isdyl @ Sep 11 2018, 12:51 PM) *
If you have to replace the switch, make sure the little arm is behind the big washer on the brake rod. The switch is held open by the brake rod, and closes with a spring when the brake is depressed.
Also be careful of wire routing to the brake light switch. You can accidentally get it in the way of the accelerator bell crank. That will pull the wires off the switch. And the MOT won't like that.
isdyl   Early 914 brake light switch   Sep 11 2018, 02:08 AM
Tbrown4x4   I just replaced my M/Cylinder with a 19mm 914 Rubb...   Sep 11 2018, 02:26 AM
isdyl   Oh thats interesting thanks - maybe one of the wir...   Sep 11 2018, 02:54 AM
isdyl   Oh thats interesting thanks - maybe one of the wi...   Sep 11 2018, 03:09 AM
Tbrown4x4   I'd check for you, but I'm at work. What y...   Sep 11 2018, 04:28 AM
Tbrown4x4   I don't think brake fluid should be coming out...   Sep 11 2018, 04:53 AM
isdyl   Hi, Mine is an early '73 and I don't think...   Sep 11 2018, 06:01 AM
Tbrown4x4   I think 35 is the switch on the brake pedal. What ...   Sep 11 2018, 06:58 AM
ClayPerrine   Hi, I'm have a difficult time obtaining a bra...   Sep 11 2018, 11:36 AM
isdyl   Ah yes! Brilliant - thanks - this forum is exc...   Sep 11 2018, 11:51 AM
ClayPerrine   Ah yes! Brilliant - thanks - this forum is ex...   Sep 11 2018, 02:55 PM
isdyl   Ok so the other switch isn't available either...   Sep 12 2018, 01:23 PM
bbrock   You mean this one? https://www.amazon.com/Brake-Sw...   Sep 12 2018, 02:33 PM
isdyl   Yes exactly those ones. I’ve ordered 3 so far bu...   Sep 12 2018, 02:39 PM
bbrock   Yes exactly those ones. I’ve ordered 3 so far b...   Sep 12 2018, 02:46 PM
914Sixer   I have one. Contact me. It is also a stock VW Bu...   Sep 12 2018, 08:25 PM
isdyl   I have one. Contact me. It is also a stock VW B...   Sep 13 2018, 10:39 AM
914Sixer   Sent you a PM   Sep 13 2018, 03:34 PM
914Sixer   I only have a clean used one. Yours for free now....   Sep 14 2018, 12:44 PM
isdyl   Wow thats fantastic - thank you so much! I mus...   Sep 14 2018, 02:49 PM
isdyl   Brilliant - 914Sixer has sent me one - thank you v...   Sep 16 2018, 01:50 AM
isdyl   Its arrived! Thank you very much again. Dylan   Sep 23 2018, 01:39 PM
isdyl   Hi, sorry to resurrect my old thread, but I'm ...   Apr 11 2019, 03:07 AM
Spoke   I replaced the brake pressure switch kindly sent ...   Apr 11 2019, 07:42 AM
isdyl   Hi - sorry its taken me a long time to follow this...   Jul 10 2019, 07:43 AM
914Sixer   Check your hand brake switch. Make sure it is pu...   Apr 11 2019, 06:28 AM
isdyl   Thank you - I'll have a good look at that. D   Apr 11 2019, 03:03 PM
- Lo-Fi Version Time is now: 1st May 2024 - 08:46 PM
