Early 914 brake light switch |
isdyl |
Sep 11 2018, 02:08 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
Attached image(s) |
isdyl |
Sep 12 2018, 02:39 PM
Yes exactly those ones. I’ve ordered 3 so far but each time the seller has come back to me saying sorry they aren’t available. These guys just wait till they get an order and order it from Bosch. Bosch have none.
bbrock |
Sep 12 2018, 02:46 PM
Yes exactly those ones. I’ve ordered 3 so far but each time the seller has come back to me saying sorry they aren’t available. These guys just wait till they get an order and order it from Bosch. Bosch have none. Oh, that sucks. I'd contact 914rubber about the warning switch on the master cylinder. They include them on the master cylinders they make so are getting them from somewhere. It looks like they are both still available from Porsche but not cheap. Either could save your life though so I wouldn't delete them. |
Lo-Fi Version | Time is now: 1st May 2024 - 11:00 PM |
