Early 914 brake light switch |
isdyl |
Sep 11 2018, 02:08 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
Attached image(s) |
isdyl |
Apr 11 2019, 03:07 AM
Hi, sorry to resurrect my old thread, but I'm still having a few issues with brake pressure. I've done quite a lot of searching around but before I waste any more time removing wheels again I thought I'd describe my symptoms and see if I'm barking up the wrong tree!
I replaced the brake pressure switch kindly sent to me by 914Sixer and have bled the brakes a couple of times.When I'm driving or stationary with the engine on I get a clicking/ticking from the flasher relay (but no warning light flashing). If I press the brake pedal the clicking/ticking stops for about 5 seconds and then starts again. It I apply the parking brake when stationary the light on the dash flashes in time with the ticking (as it should). Indicators all work as they should. In some places I have read that the switch needs resetting, but I don't think this is that type as there is no reset button. I wonder if I just need to keep bleeding the brakes - maybe I have air trapped somewhere? I have read that air can get trapped in the brake proportioning valve - could this cause this problem please? Thanks, Dylan |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:58 AM |
