Early 914 brake light switch |
isdyl |
Sep 11 2018, 02:08 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
Attached image(s) |
914Sixer |
Apr 11 2019, 06:28 AM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check your hand brake switch. Make sure it is pushing it all the way down. Easy to take out the screw and check for movement or corrosion. It is a single pole VW door switch. There is NO reset on MC switch.
Lo-Fi Version | Time is now: 1st May 2024 - 11:49 PM |
