Billet 82mm Type 4 Crankshaft by Marine Crankshaft usa |
drgouk |
Sep 11 2018, 03:36 PM
Newbie Group: Members Posts: 14 Joined: 7-March 15 From: NZ Member No.: 18,494 Region Association: None |
Billet 82mm type 4 crankshaft by Marine crankshaft in Santa Ana USA.
Lightened big ends, simply a beautiful crank. I have a matching set of SAENZ rods, 5.352" 500grams, 300m steel, 625 custom age bolts, best of the best. $2000, crank and rods as a package. Going to a six cylinder, all my type 4 stuff must go! Attached thumbnail(s) |
drgouk |
Sep 13 2018, 02:08 AM
I also have many other quality high performance type 4 parts:
Nos type 4 engine case machined for type 1 lifters and porsche fan New 45mm jenvey throttle bodies Csp linkage Csp idf manifolds 96mm je pistons/barrels 4340 flywheel Dailey engineering drysump pump Klaus 911 fan and shroud And many other small parts. Please contact me if any of the above parts are of interest. Thanks David Gouk |
finchmunoz |
Mar 23 2019, 06:23 AM
Newbie Group: Members Posts: 34 Joined: 3-July 11 From: Manila, Philippines Member No.: 13,272 Region Association: None |
I also have many other quality high performance type 4 parts: Nos type 4 engine case machined for type 1 lifters and porsche fan New 45mm jenvey throttle bodies Csp linkage Csp idf manifolds 96mm je pistons/barrels 4340 flywheel Dailey engineering drysump pump Klaus 911 fan and shroud And many other small parts. Please contact me if any of the above parts are of interest. Thanks David Gouk What cylinder heads do you have? |
peteyd |
Mar 26 2019, 08:52 AM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
PM sent
RFoulds |
Mar 27 2019, 01:52 PM
Green Teen 66 Group: Members Posts: 836 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
PM sent. with email. please reply when you can.
Chi-town |
Mar 27 2019, 10:45 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Very nice crank, Marine does incredible work
Lo-Fi Version | Time is now: 26th April 2024 - 01:18 PM |
