3 Pages V  1 2 3 >
> LE 15322, It will be six years in November
rstover
post Sep 11 2018, 04:39 PM
I was not going to start thread until the car was home, but it is getting close and I want to share some pictures of the car and the progress.
post Sep 11 2018, 04:42 PM
914-6 GT in waiting
Congrats. (IMG:style_emoticons/default/beerchug.gif)
rgalla9146
post Sep 11 2018, 04:50 PM
WOW ! (IMG:style_emoticons/default/wub.gif)
914_7T3
post Sep 11 2018, 05:18 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well?
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
poorsche914
QUOTE(rgalla9146 @ Sep 11 2018, 06:50 PM) *
rstover
post Sep 11 2018, 06:41 PM
My favorite section of a 914 is the rear deck. The simple line and immense flat area sets it apart from all others. I received this from the painter today and it made my day. He thought it was good. I thought it was crazy good. Some guy named Jeff told me to get it painted in single stage. I hope he approves.
914Sixer
post Sep 11 2018, 09:18 PM
I know the restoration on this car. I can't wait to see the paint in person.
rhodyguy
post Sep 11 2018, 09:21 PM
Where's my fly?
It took me a second to figure out the picture. Quite the reflection.
billh1963
post Sep 12 2018, 07:41 AM
Car Hoarder!
That reflection in the movie is awesome!
EdwardBlume
post Sep 12 2018, 08:10 AM
rstover
post Sep 12 2018, 04:57 PM
QUOTE(914_7T3 @ Sep 11 2018, 06:18 PM) *
At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint.
There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was.
rstover
post Sep 12 2018, 04:59 PM
914_7T3
post Sep 13 2018, 03:51 PM
QUOTE(rstover @ Sep 12 2018, 03:59 PM) *
I know exactly what you mean!
euro911
post Sep 13 2018, 04:04 PM
Wow ... looks great, Roger. Now I can see why you desired the nicest trim pieces available to finish it off. Glad to hear the upper windshield trim made the trip OK, and that it met with your expectations. Looking forward to the progression to completion.
rstover
post Sep 13 2018, 05:55 PM
QUOTE(914_7T3 @ Sep 13 2018, 04:51 PM) *
The pad on the flat part looks familiar. What kind of material do you think it is?
rstover
post Sep 13 2018, 06:00 PM
The pad on the right was the one that caused a problem on my car.
aggiezig
post Sep 13 2018, 08:04 PM
Porsche Wannabe
your reflections are stunning!!!
914_7T3
post Sep 13 2018, 11:01 PM
QUOTE(rstover @ Sep 13 2018, 05:00 PM) *
That was the original pad from the factory and they retain moisture. I will be replacing with adhesive backed rubber!
rstover
post Nov 5 2018, 06:55 PM
The air box is in. I was very apprehensive about getting it back in place and really did not have a plan. I don't read all the post, but I had not seen one that said it was easy.
I had a few starts and stops and a few redos. I seperated box from fan then installed the box. With the box in I didn't have room to attach the control wire.
Attached Image (IMG:style_emoticons/default/headbang.gif)
Start over. Removed air box to allow room to attach control wire. Even with the box removed this was the most difficult task. I had marked the spot where the wire was attached so I knew where it needed to be. With the washers and a tight fit this gave me a fit. I ended up putting in the bolt with the small hole in and then the near washer and used a little super glue to hold them in place. After the nut secured the wire in place I attached the outer rubber cable. With the wire control in place the fan will set flat and there is room to insert air box. It slid up easily and tightened the box in place.
I hooked up electric wire before attaching fan.
Getting the fan bolted to box was a challenge. I had to get some longer 5 mm bolts to align it then hold it in place while I got the short bolts in.
I don't know if valve is supposed to be completely close, but it wont be on this car.
At this position the fan was blowing full and flat was wide open. I don't know if this is perfect , but I don't want to start over.
rstover
post Nov 17 2018, 04:44 PM
Finished the dash today. It was another one of the items to do that was completely new to me. Thanks to all 914 world members that have shared information and my wife the project was finished and I was happy with the result.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 15th July 2019 - 05:13 PM
