Mirror turn signals., Has anyone done this? |
bmtrnavsky |
Sep 12 2018, 08:42 AM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
One of the things I am thinking about doing is adding turn signals to my mirrors. Its a minor addition, but it adds a touch of safety and depending on how I do it won't cost very much.
I found this: https://www.amazon.com/iJDMTOY-Universal-Tu...t/dp/B008B86O7Q But was curious how others have done it? BTW I do not have the original mirror. the current mirror is a baby turbo. I will likely change that out for something else, but no idea what yet. |
eitnurg |
Sep 12 2018, 11:02 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
.........just where they are the most vulnerable: they get banged, knocked, scraped and eventually break and stop working. Every time I go to a Mercedes dealer to buy a replacement I curse the numbskull designer who thought it was a good idea to place them there.....
jim_hoyland |
Sep 12 2018, 11:48 AM
Get that VIN ? Group: Members Posts: 9,261 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Looks like a better fit for a flag mirror ? And might be more suitable for slower-moving cars and trucks ?
Valy |
Sep 12 2018, 11:55 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Adding that inside the mirror doesn't make a lot of sense as it can only be seen from behind.
You would probably want them on the outside of the mirror so the will get lateral visibility. |
RickS |
Sep 12 2018, 08:16 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
After nearly getting hit by someone not seeing my front turn signals I just cross wired the front warts to blink with blinkers like GM cars used to. Don’t ask me how I did it since it was about 10 years ago.
Chris914n6 |
Sep 12 2018, 11:14 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Nobody is going to be looking for flashers in an old car mirror. The flashing wart is a good idea.
rgolia |
Sep 13 2018, 05:06 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
The flashing wart works great especially with a good led bulb.
eitnurg |
Sep 13 2018, 12:14 PM
bmtrnavsky |
Sep 14 2018, 08:01 AM
My truck has the red flashers in the mirror... I figure every bit helps... I am seriously looking at the flashing wart though. that's brilliant. Sadly I also wanted to french those in a little so they were less "out there" that may defeat the purpose. I wonder if I can figure out how to make both sides of the flag mirror flash?
914forme |
Sep 14 2018, 01:22 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I did it once with a Miata Mirror. Added a few LEDS to the outer edge, worked great. Do not have pictures, sorry that was a long time ago.
Big Len |
Sep 14 2018, 02:33 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Using the side markers seems like a much better idea.
RickS |
Sep 14 2018, 07:08 PM
If I remember correctly I ran a positive jumper from the forward turn signal to the negative/ground on the wart. With running/headlights off the positive lead on the wart acts as the ground. With them on the flasher short circuits the wart light and it flashes. Use a multimeter to verify this is right.
But I could be wrong so if you go up in flames do this mod at your own risk |
Chris914n6 |
Sep 14 2018, 10:59 PM
I think I've seen motorcycle mirrors with turn lights built in. Might be hard to find a big enough one to see with though.
Lo-Fi Version | Time is now: 25th April 2024 - 10:17 AM |
