Clutch/accelerator cable set-up, How much free play? |
ChrisReale |
Jul 13 2003, 07:14 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
When tightening your clutch cable, how much free play do you want in the pedal? When adjusting the acc. cable at the throttle body, how loose should it be? When I had my acc. cable too tight, I would push the clutch in, and the rpm's would shoot up. So, what is the right set up?
DNHunt |
Jul 13 2003, 09:03 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Chris,
My acc cable has quite a bit of free play at the throttle body. I can move it to the side about 1/2" without moving the actual throttle. It always seemed like too much to me but, I never could notice any dead peddle so I left it alone. I quess it's that old "if it ain't busted don't fix it" or maybe my feet are so insensitive I can't feel it. With the clutch on the otherhand, I've always been told to adjust it out so there is only about an inch of free travel. The reason I've been told is that it allows a little easier shifting into 1st. Dave |
SirAndy |
Jul 13 2003, 10:44 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(ChrisReale @ Jul 13 2003, 06:14 PM) When I had my acc. cable too tight, I would push the clutch in, and the rpm's would shoot up. So, what is the right set up? sounds like your 2 cables are wrapped around each other. no matter how tight your accel cable is, the clutch should never effect your rpm ... check the front center tunnel, where the clutch cable comes out of the tube and see if the accel cable is wrapped around it. later, Andy |
Porsche Rescue |
Jul 14 2003, 09:25 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I also think you have them twisted. I have done it twice. Drove all day with no problem and then all of a sudden it bound up and engine would not return to idle. Other time was more interesting (different car). Autocrossing my six and when I got on it hard the clutch would slip. Thought I was overpowering my clutch. Turned out the cables were twisted and when I floored the throttle I was partially releasing the clutch. Had to use a mirror at front of tunnel with flashlight shining forward from the shift lever hole to see it clearly. Sure an easier and cheaper fix than a new clutch!
Brad Roberts |
Jul 14 2003, 10:04 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Dave is right on.
I set them up with 3/4 - 1 inch of pedal travel depending on the heigth of the owner. Your standing a 99% chance you have the cables "wrapped". Make sure BOTH stops are in place and adjusted correctly on the pedal board. Also make sure your getting full throttle without "pulling" on the intake plenum.... which means you need to adjust the throttle stop below the pedal. B |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:37 AM |
