Bake upgrade?? |
Bake upgrade?? |
MikeP |
Jun 16 2005, 12:56 PM
Member Group: Members Posts: 321 Joined: 13-June 05 From: San Jose, CA Member No.: 4,268 |
I have a set of custom 4 bolt wheels I really like but I want better brakes. What is the best setup to run/where do I get it? Duh I mean BRAKE upgrade
ArtechnikA |
Jun 16 2005, 12:58 PM
i recommend a convection oven, probably with a pizza stone.
Mueller |
Jun 16 2005, 01:00 PM
I'm very happy with my Viking Oven for Baking , best upgrade I've done (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1110991993.jpg) |
MikeP |
Jun 16 2005, 01:01 PM
fuck, I'm never going to hear the end of that am I?
lapuwali |
An EZ Bake would be cheaper.
lapuwali |
Jun 16 2005, 01:04 PM
You have to define first what you want in "better brakes". Most people slag off the stock system simply because it's stock, not because they've actually had any problems with it.
Do you want less pedal effort? Do you NEED more fade resistance? Have you actually had your brakes fade? Have you ever rebuilt your stock brakes? If you want big vented rotors and four-piston calipers for the trick factor, then lay out the list of what bling factor you want, and ask about that specifically. |
ArtechnikA |
good pads. fresh fluid. new OEM hoses. maybe new rotors if yours are nearing the wear limit; this will mean new bearings up front, which is also good. unless you have a huge power increase, or you can't lock the brakes, or you actively and aggressively track the car, that will be all you need. you can spend as much as you want, but plus or minus a little, if you can lock the wheels, you have all the brake you need... ( sorry about giving you a hard time with the thread title -- some straght lines are just too good to resist... ) |
Mueller |
Jun 16 2005, 01:05 PM
everyone likes a good ass, but no one likes a smart ass (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mike, in the picture above, you'll see some new 7075 billet aluminum hubs that are for sale in the 'club store. These go right onto your stock /4 struts ('73-'76),these allow you to bolt on 911 vented rotors and use 911 front calipers. A few people are using this setup with Volvo calipers, as for the rotors in the picture, those are mine, 12.20" diameter vented Wilwood rotors with an aluminum hat, I will be using aluminum turbo RX-7 calipers. Rich, Mike has a nice V8 conversion car, close to 400hp I think (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
MikeP |
Jun 16 2005, 01:06 PM
I sould clarify this is in a 475bhp V8 car.
914werke |
Jun 16 2005, 01:10 PM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So mike tell us more about the rotors/hats? (sorry for the Hijack) ,
Larger swept area? less sprung weight? Full floating? $$$? |
MikeP |
Jun 16 2005, 01:18 PM
do they change the wheel spacing? anyone have first hand knowledge of renegade's setup?
Mueller |
Jun 16 2005, 01:19 PM
rotors: 35 to 40 each hats: 120 each (I'm sure I can have them made much, much cheaper for qty's) full floating? no, more money and I've never used or dealt with them before.. I have not weighed this setup, but I'd have to say yes, it's lighter even with the 4 piston caliper........ |
lapuwali |
Jun 16 2005, 01:20 PM
You also need to think about the rear brakes. With a V8 esp, you're going to have enough rear weight bias that more rear brakes would be a good idea. Apparently, spacers are available (ask Eric Shea) for the stock rear calipers to run with vented rotors. Which rotors is another matter, but perhaps redrilled Carrera rotors will work?
If you're going with front calipers with more piston area, you'll need different rear calipers, too, or you'll end up with a front-biased brake system, anyway. The trouble here is the parking brake. Some people advocate a separate cable-operated caliper (Wilwood has 'em). Some like the 911 setup (but that's only 5-lug). Question: can you put spacers in the stock FRONT calipers for vented rotors? If so, this seems to me to be a good stab at a setup, as brake balance will be the same as stock, but you'll have more heat capacity with vented rotors all round. |
Mueller |
Jun 16 2005, 01:22 PM
no change in offset, I am running BBS Racing studs with 1.125" spacers on mine: (IMG:http://www.914world.com/bbs2/uploads/post-2-1110341185.jpg) shown with rusty 911 rotor for mock up...I still need to remove some material from the spacer to lighten it up some. |
MikeP |
Jun 16 2005, 01:36 PM
Thanks Mike, I'll probably be picking up a set from you shortly.
Qarl |
Jun 16 2005, 03:20 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Please stay away from Mike Mueller's rusty rotors. No matter how cheap he offers them to you, you should not be bolting on rusty parts!
MikeP |
Jun 16 2005, 03:25 PM
I don't know, if that isn't a face you can trust, what is?
Mueller |
Jun 16 2005, 03:31 PM
Q-tip is jealous cause my parts are on my car and not sitting all pretty on the front room floor (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) go ahead Qarl, post some of your "pretty" parts (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
MikeP |
Jun 16 2005, 03:47 PM
ouch. as the glove falls to the floor a collective "gasp" was hear throughout the forum......
SpecialK |
Jun 16 2005, 04:53 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Ding, ding...
Lo-Fi Version | Time is now: 3rd May 2024 - 10:13 AM |
