Thread Sealer On Exhaust Manifold Stud, What Should I Use, If Anything |
motorvated |
Sep 13 2018, 05:57 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Took my exhaust off yesterday and one of the exhaust manifold studs unscrewed with the nut attached. The threads are good, so I shouldn't have a problem putting it back in. So my question is whether or not I should put some thread sealer on the stud when I screw it back in, and if so, should I use something like Locktite blue strong or red permanent thread sealer. I'm thinking the heat may make using thread sealer a mute point, so I'm asking the Brain Trust of the World for advice.
Thanks, Mike |
Chi-town |
Sep 13 2018, 06:29 PM
Most thread lockers will just burn off with a few exceptions that loc-tite makes and you don't want to use them in aluminum.
Are you using a locking nut or a nut with a lock washer? If it's a locking nut you may want to switch to a nut and lock washer to avoid this. If the stud coming out doesn't hurt anything toss a little anti-seize on it to make sure it doesn't bugger up the threads going in or out and just make sure it's tight when reinstalled. |
motorvated |
Sep 13 2018, 07:08 PM
Most thread lockers will just burn off with a few exceptions that loc-tite makes and you don't want to use them in aluminum. Are you using a locking nut or a nut with a lock washer? If it's a locking nut you may want to switch to a nut and lock washer to avoid this. If the stud coming out doesn't hurt anything toss a little anti-seize on it to make sure it doesn't bugger up the threads going in or out and just make sure it's tight when reinstalled. That's what I was thinking, none of the thread lockers would hold up to the heat. I have the copper nuts which seem to work well overall. I'd prefer if the nut would come off rather than the stud unscrewing, as I don't want to bugger up the threads in the aluminum head and have to go the time-sert or heliocoil route. Thanks for your advice. |
JamesM |
Sep 13 2018, 08:39 PM
Senior Member Group: Members Posts: 1,875 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
The copper lock nuts are great at pulling exhaust studs and never letting go. I have had to replace almost every stud I ever attempted to install them on. I wouldn't use them again if you paid me to!
These are my new go to for exhaust nuts: http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm Having the extra space is REALLY nice to keep your socket from jamming against the pipes and the 13mm flange is nice for multiple reasons. Was so happy when i found these. |
TheCabinetmaker |
Sep 13 2018, 09:08 PM
I drive my car everyday Group: Members Posts: 8,299 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have the same feelings as James on the copper nuts. Won't use them
injunmort |
Sep 14 2018, 04:52 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
milk of magnersia on the threads
Krieger |
Sep 14 2018, 07:22 AM
Advanced Member Group: Members Posts: 4,686 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I used the copper plated nuts with antiseize on threads. No problems with removal on a tracked 6 cylinder.
rhodyguy |
Sep 14 2018, 07:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Get a replacement stud. Not that long ago Len Hoffman noted not to use the copper nuts and simply double nut the stud and use a anti-seize product.
Lo-Fi Version | Time is now: 29th March 2024 - 03:39 AM |
