Thread Sealer On Exhaust Manifold Stud, What Should I Use, If Anything |
motorvated |
Sep 13 2018, 05:57 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Took my exhaust off yesterday and one of the exhaust manifold studs unscrewed with the nut attached. The threads are good, so I shouldn't have a problem putting it back in. So my question is whether or not I should put some thread sealer on the stud when I screw it back in, and if so, should I use something like Locktite blue strong or red permanent thread sealer. I'm thinking the heat may make using thread sealer a mute point, so I'm asking the Brain Trust of the World for advice.
Thanks, Mike |
Chi-town |
Sep 13 2018, 06:29 PM
Most thread lockers will just burn off with a few exceptions that loc-tite makes and you don't want to use them in aluminum.
Are you using a locking nut or a nut with a lock washer? If it's a locking nut you may want to switch to a nut and lock washer to avoid this. If the stud coming out doesn't hurt anything toss a little anti-seize on it to make sure it doesn't bugger up the threads going in or out and just make sure it's tight when reinstalled. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:27 AM |
