Clean slate...now what? |
John90290 |
Sep 13 2018, 06:14 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Removed the rust acid washed and use the POR15 on the floor pan. Cut out patched welded and use the POR15 in the hell hole. Figuring out what to do next? Do I put the old heat/sound insulation stuff back on and put contact cement on my beautiful paint job in the engine bay and back of seat? I have the old ones I pulled off. Using the 1975 technology for sound and hear versus new self stick items that Protect against both as well. New stuf Has to be better or at least the same? Also how bout I leave the engine insulation out all together and just use thick stuff behind seat. The old stuff , behind seat and engine bay my gether must weigh 60 pounds. Don’t really want to put the tar stuff back on the floor pan either as it took me a week to remove and seemed to trap water underneath.
I want this car to look and stay as oem as possible but it’s not going to Amelia island or pebble beach. Thanks for all the input! John |
dr914@autoatlanta.com |
Sep 14 2018, 12:36 PM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
use the original floor pan tar kit that is die cut from the originals and then paint your cars color. Will look perfect and dampen well. There is also a kit for behind the vinyl covered back pad
Lo-Fi Version | Time is now: 28th March 2024 - 04:00 PM |
