What about Roll Center?, where is it, how do you guys handle it? |
Chi-town |
Sep 13 2018, 08:50 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I think I've ready about a dozen threads relating to bump steer.
I see the issue and it's easily remedied by the aftermarket parts available. Rear bump steer or "passive rear steer" as Honda called it in the CRX doesn't really worry me. What I'm noticing in all the images I see of lowered front suspensions is the angle of the lower control arm and the comments about lack of ride quality. If you look at a pic of a stock height suspension, the arm sits at about a 20 degree angle downwards (estimated). If you look at a lowered car the angle is usually less than 10 degrees or even parallel with the ground. (eek!) I know we have a few racers / engineers here on the forum, has anyone calculated the roll center of the car stock / lowered? Has anyone tried an extended lower ball joint? I've seen de-cambered but not extended. I'm curious to see what you guys think. |
Lo-Fi Version | Time is now: 20th April 2024 - 02:12 AM |
