New 914-6 Owner and Weber Recommendation |
AHudson |
Sep 14 2018, 08:10 AM
Member Group: Members Posts: 55 Joined: 13-May 18 From: Alabama Member No.: 22,112 Region Association: South East States |
Hi Folks, first post here and delighted to have been reading, studying, learning a ton.
Brief history: Long time Porsche fan, starting with - you guessed it - a 914 back in the days they were nearly free. As a broke college student, free was about my price range, but the 914 introduced me to a world far beyond the British cars that had been leaking on my rented driveways. Went on to own and almost always have a 911 of some sort in the garage, keeping company with several of "those" Italian cars until move to a semi remote lake a few years back stripped me of service accessibility. This, and a recent business sale/retirement, forced me to shed the complicated and needy in favor of the more robust, serviceable, and dare I say 'simpler' cars. Got my first 914 in 25 years about 4 months ago. A 76 2.0 (of course) in black/black. Took me straight back in time and I couldn't quit smiling on the 50 mile drive back to my little garage. Super solid, wonderful car, with a good history. I jumped into cleaning, discovery, improvement. Fast forward: Two weekends ago, after much protracted negotiation, I added a 914-6. (I had to buy an SC with it to make the deal.) And it is a jewel. Slightly neglected, but very easily reclaimable to show worthiness. Not kidding myself on that as I've been through everything from rusted hulks brought back to only needing air in the tires. The car is a two time former Parade winner, and has seen delicate care since. It has THE most complete documentation of any car I've ever owned. (Maybe 150?) It may not be the best 14-6 around, but to my eye, it is quite good, quite complete. There will be more posts about the particulars as I continue this journey, but right now, needing my Webers built as they pop when warm and throttle shaft (drivers side) is pretty wobbly. The seller provided me with a spare set (!) numbered for a 914-6, so I could get those built to minimize downtime, or get both built "just because". <-- A very expensive phrase for car lovers! Anyway, happy to be a small part of a great forum. You folks have taught me much in my short time here, I have much more to learn! Sorry pics of the car on Day One in my little place... Attached image(s) |
toolguy |
Sep 17 2018, 11:28 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Hopefully you still have the stock IDTP Webbers with the 27mm venturies and stock jet setup. . Personal opinion, I'd choose to get them properly cleaned and restored as they are best suited for the low power 914-6 911T motors, mostly because their progression holes are different than the IDA [911S] carbs which have 30mm venturies and not as much off idle / low speed performance oriented.
I had dismal at best experience with PMO carbs and a complete lack of help from the manufacturer who kept insisting there was something wrong with my motor. . My set of late 1990's PMO's had 4 progression holes and were way too rich directly off idle for a 2.0 T motor. . Once I found a good set of Webber bodies and restored them , the rich progression issues were resolved and the same motor responded accordingly. The only benefit I found to the PMO's was the visible fuel bowl level sight, which is an immediate tip off they are replacement carbs if you want originality. As for your popping, try cleaning all the idle jets and richen the idle mixture screw a tad for the popping barrel [ or barrels] as a stop gap remedy until you can disassemble them and clean all jets and passages. . that means pulling all the passage plugs to ensure removal of all debris. Also make sure the squirters for the accelerator pump circuit are all working. . they have very tiny outlet holes and plug up easily. . . As for worn throttle shafts, since the wear is below the throttle plates, they will cause a lean condition at idle if wear is too excessive. . if not too worn, this can be compensated for with the idle mixture screws but at some point will need proper rebush or oversized throttle shafts . |
Lo-Fi Version | Time is now: 5th May 2024 - 01:44 PM |
