Wheel spacers (Sold) and rear springs (Sold), 21mm spacers 477-501-701 and Welmeister rear springs |
69_Lex |
Sep 16 2018, 12:54 PM
Member Group: Members Posts: 52 Joined: 28-June 08 From: wyoming Member No.: 9,226 Region Association: None |
Wheel spacers 477-501-701
Weltmeister rear springs 14 3/8" tall,believe they are 180#, never used coated with POR15. |
Chris914n6 |
Sep 16 2018, 03:27 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My 180s are linear. Those look like the 140lb progressives. But I'm not an expert.
mgp4591 |
Sep 16 2018, 09:07 PM
914 Guru Group: Members Posts: 5,363 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
What wheel/tire combination were you using with those spacers?
Chris914n6 |
Sep 16 2018, 10:36 PM
^^ they are 21mm off an early 944. I use them on the front to correct the offset with my Box 16s. I also used the 944 66mm long studs.
Get your car running already slacker |
Literati914 |
Sep 17 2018, 06:26 AM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
PM sent on rear springs
mgp4591 |
Sep 17 2018, 09:05 PM
^^ they are 21mm off an early 944. I use them on the front to correct the offset with my Box 16s. I also used the 944 66mm long studs. Get your car running already slacker Hmmm.... so you're member #431 and I'm member 14,700 and some.... Oh, and I've had a small, how do you say, distraction in my build? Gee, I wonder if they'll fit the 944 hubs you sold me?? Sorry for the hijack Lex.... |
Lo-Fi Version | Time is now: 19th April 2024 - 09:14 AM |
