1st Gear Difficult to Engage |
jkb944t |
Sep 17 2018, 11:12 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I have had a problem with engaging 1st gear ever since I have had this 914. I have already done all the bushings and rebuilt the transmission. I can easily engage all the other gears including reverse.
I really have to pull hard to the left and down to actually engage 1st gear. It feels like a linkage issue but reverse is very easy to engage so I am not sure that is the case. Does this just sound like a basic linkage adjustment issue? Any thoughts or ideas would be appreciated. Jeff B |
Dr Evil |
Sep 18 2018, 08:56 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Man I chase this issue for customers, often. On rare occasions this happens with a rebuild, too. While it is often endemic of the 901 box, there are things that can be done with time and effort, if all externals are 100%. However, ass mentioned above, there are external issues that are often overlooked. The tube is a big one. First does not take kindly to poorly adjusted clutch cables, things in the tunnel hitting the shifter, poor adjustment, bushings, etc. IN the end, the only thing internally to do is change the teeth/band/break bands/blocks/slider and hope for the best. I can often find a less stiff or more stiff band to change this condition depending on the condition of the one that came out of the box. Its a read and react scenario at that point.
Lo-Fi Version | Time is now: 13th May 2024 - 03:15 AM |
