Stumped, motor won't fire on #1 |
Rusty |
Sep 17 2018, 04:25 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
We're stumped. I even caved and took it to my local VW expert for help.
Background: The car had been stored for 7-8 years. Before storage, it had been worked on by a third party (including replacing the distrubutor, IIRC). When the car was stored, it was running poorly. Symptom: Car won't fire on cylinder #1, but fires fine on 2 thru 4. (Was it firing on #1 prior to storage... I dunno. I stored it out of frustration.) Motor: 1973 1.7L, dual Weber carbs, Pertronix points replacement in 009 distributor. Details: Car has air, fuel, and spark. Air: Valves are adjusted correctly (.006) and timing is on. Compression on all cylinders is 90-95 pounds. Heat exchanger removed and checked for obstruction. Covering/blocking the air intake on #1 has no effect to the motor running. Fuel: Carb on cylinders 1/2 has been cleaned and adjusted. We can watch fuel go into the cylinder. Some of it ends up as white smoke going out the exhaust. There is an oil leak on the drivers side of the motor and the oil smells faintly of fuel. Spark: Plug wires are routed correctly. Taking a plug out and laying it on engine tin, spark is strong. Wires, cap, rotor, and plugs have all been swapped out. Pulling the plug wire on #1 at any RPM results in no change. I talked to my guy today... he's very well regarded in the area. He's as stumped as I am. Any thoughts? |
Spoke |
Sep 18 2018, 08:17 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Have you checked the airflow into each cylinder using a sync meter? This will let you know that each cylinder is pulling the same volume of air. Even by putting your hand over the opening of the carb you should be able to feel the vacuum.
struckn |
Sep 18 2018, 08:54 AM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
I'm know expert but I had a similar condition that turned out to be a dropped a Valve Seat?
Also, was a Cam for Carburetor conversion from FI made. Might cause for a rough running engine condition. Did it run right before you put it in storage? |
Lo-Fi Version | Time is now: 19th May 2024 - 10:42 PM |
