Stumped, motor won't fire on #1 |
Rusty |
Sep 17 2018, 04:25 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
We're stumped. I even caved and took it to my local VW expert for help.
Background: The car had been stored for 7-8 years. Before storage, it had been worked on by a third party (including replacing the distrubutor, IIRC). When the car was stored, it was running poorly. Symptom: Car won't fire on cylinder #1, but fires fine on 2 thru 4. (Was it firing on #1 prior to storage... I dunno. I stored it out of frustration.) Motor: 1973 1.7L, dual Weber carbs, Pertronix points replacement in 009 distributor. Details: Car has air, fuel, and spark. Air: Valves are adjusted correctly (.006) and timing is on. Compression on all cylinders is 90-95 pounds. Heat exchanger removed and checked for obstruction. Covering/blocking the air intake on #1 has no effect to the motor running. Fuel: Carb on cylinders 1/2 has been cleaned and adjusted. We can watch fuel go into the cylinder. Some of it ends up as white smoke going out the exhaust. There is an oil leak on the drivers side of the motor and the oil smells faintly of fuel. Spark: Plug wires are routed correctly. Taking a plug out and laying it on engine tin, spark is strong. Wires, cap, rotor, and plugs have all been swapped out. Pulling the plug wire on #1 at any RPM results in no change. I talked to my guy today... he's very well regarded in the area. He's as stumped as I am. Any thoughts? |
IronHillRestorations |
Sep 18 2018, 11:29 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I too suspect a fuel delivery problem for that barrel. Look down the throat of #1 carb barrel, you should see fuel squirting when you open the throttle enough to actuate the accel pump. Spraying some fuel down the barrel (with spray bottle in a leather gloved hand, and fire extinguisher within reach) will tell you if you have a fuel delivery problem.
Could also be a valve problem, if so, probably intake, such as stuck valve, bad rocker arm, bad lobe on cam. This could be seen by taking off the valve cover and turning the engine. First thing I'd do is warm it up and block the throttle at about 1800 rpm's and squirt some fuel down #1 barrel. Just be really careful. In theory you could use ether, but that's not good on your engine. |
wndsrfr |
Sep 18 2018, 12:20 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I too suspect a fuel delivery problem for that barrel. Look down the throat of #1 carb barrel, you should see fuel squirting when you open the throttle enough to actuate the accel pump. Spraying some fuel down the barrel (with spray bottle in a leather gloved hand, and fire extinguisher within reach) will tell you if you have a fuel delivery problem. Could also be a valve problem, if so, probably intake, such as stuck valve, bad rocker arm, bad lobe on cam. This could be seen by taking off the valve cover and turning the engine. First thing I'd do is warm it up and block the throttle at about 1800 rpm's and squirt some fuel down #1 barrel. Just be really careful. In theory you could use ether, but that's not good on your engine. Use propane....safe and effective... |
Lo-Fi Version | Time is now: 20th May 2024 - 05:23 AM |
