Ice Green 1.8 Rescue, It's 914 wrenching weather again |
Chris914n6 |
Sep 18 2018, 11:34 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Back story: Car was dropped off at Carl's Cool Cars in Las Vegas based on high recommendations. Their VW specialist rebuilt the motor, bolted it back into the car, then quit. Then Carl splits with the rent money leaving all the cars to be impounded. Owner Eric posts on the 914 FB page he needs a 914 mechanic, @Toast says she knows a guy, and now it sits in my driveway (IMG:style_emoticons/default/biggrin.gif)
My job is to get it to good Daily Driver condition, which involves figuring out the mess left over (particularly the 1.8L FI) and the usual old car fixes. This is my first time working with 914 Ljet so I'm sure I'll be asking questions, plus we'll need some parts that were lost. Parts needed: (will get longer as the days go by) -stock 1.8 banana muffler, gaskets, nuts & bolts. Custom Adds: There are a few goodies on the list... -914Rubber top dash pad -RennShift shifter -Tangerine SS lines Problems needing solved: Time keeps on ticking into the future.... Hello good look'n |
Chris914n6 |
Oct 25 2018, 06:11 PM
Day 8: Testing One Two Three Fuch
Did a pin-by-pin check of the ECU harness and it's all good. Just need to tie off the bare ends to the Altitude Compensator. Component checking is mixed. AAR - had a reading then nothing. AFM - Left 2 pins on/off. Middle 2 pins 400 ohm fixed. Right 2 pins 160-400 ohm but erratic. Shouldn't something be progressive as the flap moves? Dual Relay - full of water at some point. First will clean then power test. Injectors - Still need to clean and flow test. All the rest test good. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-431-1540512714.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-431-1540512715.2.jpg) Day 8 not over yet. |
Lo-Fi Version | Time is now: 25th April 2024 - 03:20 PM |
