Replacing Boge Front Shocks Inserts, Do I need to align the front end after? |
jagalyn |
Sep 19 2018, 12:45 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
I will be replacing the boge shock inserts on my car. Will I have to align the front end afterwards?
mepstein |
Sep 19 2018, 12:48 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No
jcd914 |
Sep 19 2018, 01:21 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If you leave the camber plate/strut mount bolted in place and just undo the single big nut and pull the shock insert down out of the camber plate/strut mount. Jim |
jagalyn |
Sep 19 2018, 07:23 PM
Thank you... I appreciate the advise.
porschetub |
Sep 20 2018, 01:37 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
No,however you will most likely need to adjust your ride height,I needed to as my car came out way to high after the change.
jcd914 |
Sep 20 2018, 09:42 PM
If you use gas pressure inserts you may have to readjust the ride hieght.
Non gas pressure inserts should not impact the ride hieght. None of the Boge inserts I have installed were gas pressured. Koni had both gas and non gas, Bilstein are gas KYBs are gas and terribly harsh. Jim |
Lo-Fi Version | Time is now: 19th May 2024 - 04:01 AM |
