GB door stay pin. Is your door popping?GB closes 10/4/18 midnight, $8 a set of 2 or $44 for entire kit- both doors including these |
Mikey914 |
Sep 19 2018, 11:42 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time).
So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Attached thumbnail(s) Attached image(s) |
n2j2ryan |
Sep 20 2018, 12:11 AM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
Yes, Thank you. Just the pins please.
DRPHIL914 |
Sep 20 2018, 06:02 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I did this rebuild as part of my full door restoration last month but yes one of my doors is popping, so I would like to get pins only for both doors, thanks!!
Phil |
914Sixer |
Sep 20 2018, 07:07 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
2 sets of pins please
Olympic 914 |
Sep 20 2018, 07:27 AM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
1 set of the pins for me also.
I see there are no holes for cotter pins, or grooves for a snap ring clip. do the pins just drop in there and stay? I don't have the original pins, I have bolts w/ nuts in there now. and they are too loose. |
Chris H. |
Sep 20 2018, 08:36 AM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I'll take a set of pins. Thank you.
markhoward |
Sep 20 2018, 08:43 AM
Member Group: Members Posts: 374 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
Would like a full kit.
porsche914gt |
Sep 20 2018, 08:52 AM
Member Group: Members Posts: 86 Joined: 20-January 04 From: Los Angeles, CA Member No.: 1,581 Region Association: None |
I need the pins please
Grafiks |
Sep 20 2018, 09:01 AM
Newbie Group: Members Posts: 8 Joined: 4-February 18 From: Banner Elk, NC Member No.: 21,863 Region Association: None |
I need the full kit.
Shadowfax |
Sep 20 2018, 09:15 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Full kit for me too, please. Thanks, Mark!
GregAmy |
Sep 20 2018, 09:23 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Is there a "how to" on this anywhere? I bought a set a couple months ago, opened the door, looked at it, and closed the door and grabbed another beer from the fridge instead.
Mikey914 |
Sep 20 2018, 11:08 AM
1 set of the pins for me also. I see there are no holes for cotter pins, or grooves for a snap ring clip. do the pins just drop in there and stay? I don't have the original pins, I have bolts w/ nuts in there now. and they are too loose. These are just a drop pin. Gravity and friction will work well here. |
Mikey914 |
Sep 20 2018, 11:09 AM
GregAmy |
Sep 20 2018, 11:23 AM
I'm quite certain I could figure it out, just takes some motivation to get started (and beer). Knowing in advance what's involved helps with that motivation (but, sadly, not the beer).
rasam |
Sep 20 2018, 11:48 AM
Newbie Group: Members Posts: 23 Joined: 10-March 15 From: Santa Fe Springs ca Member No.: 18,508 Region Association: Southern California |
I'll take a full set
Andyrew |
Sep 20 2018, 12:37 PM
In for Pins
ClayPerrine |
Sep 20 2018, 01:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I need 6 pins please.
Clay |
bbrock |
Sep 20 2018, 03:21 PM
One set of pins please.
11tenths |
Sep 20 2018, 05:29 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
I need a couple pins to replace the screws that came with the car.
And BTW- If you thought the pins that attach the emergency brake cables to the rear calipers would work, think again. -Harry |
mb911 |
Sep 20 2018, 05:52 PM
914 Guru Group: Members Posts: 6,801 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 19th April 2024 - 01:47 PM |
