GB door stay pin. Is your door popping?GB closes 10/4/18 midnight, $8 a set of 2 or $44 for entire kit- both doors including these |
Mikey914 |
Sep 25 2018, 04:02 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PMs sent to all to this point,
914four |
Sep 29 2018, 08:01 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
Received my door pins and it fixed the door popping problem I have had for many years. I thought the only way I would be able to fix it was to have the holes welded up and re-drilled to the correct dimension.
The slightly larger pin fixed my problem and now my door opens and closes smoothly just like new. Thank you 914Rubber! (IMG:style_emoticons/default/smilie_pokal.gif) Kelvin |
914werke |
Sep 29 2018, 12:19 PM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Received my door pins and it fixed the door popping problem I have had for many years. I thought the only way I would be able to fix it was to have the holes welded up and re-drilled to the correct dimension. The slightly larger pin fixed my problem and now my door opens and closes smoothly just like new. Thank you 914Rubber! (IMG:style_emoticons/default/smilie_pokal.gif) Kelvin Curious about this, since the issue is that over time the the door rollers don't roll anymore and instead glide across the nylon wearing it out. At same time the additional stress pulls the pin/jamb bracket over & over till one or both wear. The Jamb bracket tends to oval so the sound is often the pin moving back/forth in the bracket. How does the oversize pin fit without enlarging or correcting the shape of the brkt hole? |
Mikey914 |
Sep 29 2018, 10:23 PM
The mode of failure is actually galvanic corrosion. It takes metal off the pin and aluminum. My pins still fit the bracket.
914werke |
Sep 29 2018, 11:45 PM
So your refering to the Arm (alum) & pin (steel) wearing?
While I agree that occurs, my question is re the Jamb bracket. |
rob gannon |
Sep 30 2018, 07:30 AM
Newbie Group: Members Posts: 22 Joined: 31-July 11 From: b'ham alabama Member No.: 13,380 Region Association: South East States |
Received and installed pins yesterday. It took care of the popping problem!
Yeah! It’s been driving me crazy for years. Thanks, Rob |
North Coast Jim |
Sep 30 2018, 09:48 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time). So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Since I started this thread and am still looking for a solution I'll take two pins. I already have your kit to rebuild the stays. Hope this works. Do I need to go your site to order ?? |
mb911 |
Sep 30 2018, 10:58 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Very nice quality parts. For $44 you cant come close to beating.. Great job Mark
Mikey914 |
Sep 30 2018, 10:11 PM
Larmo63 |
Oct 1 2018, 11:01 PM
I'll take a set of pins, please.
Although, I think that click-click noise is pretty sexy. |
74ravenna |
Oct 2 2018, 02:16 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
I'll take a set of pins also.
My click-click is so loud it hurts my ears. I want it gone! |
jfort |
Oct 2 2018, 03:02 PM
Senior Member Group: Members Posts: 1,134 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
need full kit please
buck toenges |
Oct 2 2018, 07:55 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I got the kit in the past so I just need the pins please.
Thanks, Buck |
don-6 |
Oct 2 2018, 09:06 PM
Stock vs Modified? Group: Members Posts: 172 Joined: 7-April 14 From: Conroe, TX Member No.: 17,219 Region Association: Southwest Region |
I am interested in one full kit, please.
914-300Hemi |
Oct 2 2018, 09:15 PM
Senior Member Group: Members Posts: 1,355 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Came back Rennsport yesterday to the package with the full kit. (IMG:style_emoticons/default/piratenanner.gif)
Now I just need to find the time to install them. |
Mikey914 |
Oct 3 2018, 08:10 AM
PMs sent to all so far.
Gonna close this out tomorrow (friday) at midnight. So get them while you can at the GB price. Thanks to all. Mark |
jfort |
Oct 11 2018, 02:15 PM
got my kit. anything i should know about doing the replacement? instructions?
Mikey914 |
Oct 12 2018, 07:45 PM
The pin is simple. There is a cotter pin in the stock version (many are missing), so if it's there remove before tapping it up and out.
The door side will require removal of the panels to get the assembly out. Removal is 2 bolts pretty easy. Once out the springs need to be removed . BE CAREFUL and wear eye protection. Once springs are removed the rollers can be replaced pretty easily. I have found a bench vice helpful for the process. I have a thread here somewhere, I'll try to find it later tonight. -Mark |
Lo-Fi Version | Time is now: 25th April 2024 - 11:18 AM |
