Auxiliary oil cooler, An alternate location |
IronHillRestorations |
Sep 21 2018, 07:25 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
25 years ago when I put a 3.0 SC engine in my 914, I understood the need for additional oil cooling, but I didn’t want to cut up my frunk, or run 26 feet of oil lines. My car was a street hot rod, and really didn’t plan on doing track events, so I didn’t need the maximum possible oil cooling.
My solution back then was to put a 25 row Mocal cooler with a fan sandwiched on it in front of the right rear wheel, on the opposite side of the car from the oil tank. This worked out well, and neither I or the current owner has seen oil temps out of range. I have another street hod rod in the works and since the right rear quarter panel was removed for rust repair, I decided to revisit this alternate oil cooler location. After measuring, mocking up, and some head scratching I figured a 34 row 234 matrix Mocal cooler would fit. Here’s what I’ve come up with. To test fit a Spal puller fan, I taped it to the cooler. Two holes drilled for the front bracket and one weld nut for the rear bracket. 3 M8 cap screws are more than enough to secure the cooler |
jim912928 |
Sep 21 2018, 03:55 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I have a 75 that still has the big bumpers, so I didn't really want to cut the holes for the lines, backdate bumpers, cut valance and bumper (or leave big bumpers and cut valence/modify more), cut trunk, move spare location (probably put in an inflatable..etc. This looks easier and cleaner for something I could do pretty easy.
Lo-Fi Version | Time is now: 9th May 2024 - 08:26 AM |
