73 2.0 Has Issues, Ran GREAT and then it didn't |
Minerva's 914 |
Sep 21 2018, 08:57 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
1973 914 2.0 restored and motor rebuilt by Fat Performance and installed by Black Forest Racing. We've driven her off and on for about 750 over the past year with no problems, in fact she ran fantastic .... until she didn't. Driving around the neighborhood last week the engine bucked a few times with the tach dropping to zero before bouncing back to normal, downshifted and it seemed better only to return again while cruising along at 2800 RPM, down shifted again and since we were only a block away from home made it with no drama. Was thinking maybe an electrical issue shorting out the ignition.
I started the car yesterday evening and backed out of the garage and it stopped dead in her tracks. Turned the key to 0 then back on again and no fuel pump buzz. Proceeded to engage the starter and after several seconds of cranking I returned the switch off, then back on again. No fuel pump buzz. Checked the relay in the circuit board, switching out the relays, no change. Checked the fuses and connections seem clean so I jumped directly from the battery to pin 12 on the circuit board, turn the key to 1 and got the fuel pump buzz, turned off and back on again got the fuel pump to work. What do you guys think should be my next step? I planning to get on it early tomorrow and start chasing the wiring but hope someone here might help me narrow down the possibilities. Plan to remove the circuit board, turn it over and check the connections and double check the grounds and then check continuity from the brain, then work my way to the inside fuse panel and wherever else the electrons are circulated before reaching the fuel pump. As always THANK you guys for all you do to help the 914 live on!!! Brady |
iamchappy |
Sep 21 2018, 09:03 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
The temp sensor mounted in the head goiing bad can do that.. If your car runs when jumping the relay to excite the fuel pump i would guess the temp sensor.
Minerva's 914 |
Sep 21 2018, 09:07 PM
Minerva's 914 |
Sep 22 2018, 09:37 AM
The temp sensor mounted in the head goiing bad can do that.. If your car runs when jumping the relay to excite the fuel pump i would guess the temp sensor. Hmmm, didn't think of that but makes sense. I'll test that and provide feedback. Thx!!! Hmm, checked the resistance value while still installed in the head reading is 2.4 which I believe enrich the cold start-up but not effect the start up sequence. Black Forest Racing installed a new HTS when they were installing and setting up the FI, though it still has the original inline resister as updated by Porsche. Also a little confused as to how / why the HTS would interrupt power to the fuel pump, my problem is no power is getting to the pump thru the normal start-up procedure and power pathways, if I bypass the normal route by jumping power to pin 12 the fuel pump 1 second buzzes normally at ignition key to position 1. Maybe I'm missing something (IMG:style_emoticons/default/confused24.gif) Still search for 914 perfection. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:11 AM |
