73 2.0 Has Issues, Ran GREAT and then it didn't |
Minerva's 914 |
Sep 21 2018, 08:57 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
1973 914 2.0 restored and motor rebuilt by Fat Performance and installed by Black Forest Racing. We've driven her off and on for about 750 over the past year with no problems, in fact she ran fantastic .... until she didn't. Driving around the neighborhood last week the engine bucked a few times with the tach dropping to zero before bouncing back to normal, downshifted and it seemed better only to return again while cruising along at 2800 RPM, down shifted again and since we were only a block away from home made it with no drama. Was thinking maybe an electrical issue shorting out the ignition.
I started the car yesterday evening and backed out of the garage and it stopped dead in her tracks. Turned the key to 0 then back on again and no fuel pump buzz. Proceeded to engage the starter and after several seconds of cranking I returned the switch off, then back on again. No fuel pump buzz. Checked the relay in the circuit board, switching out the relays, no change. Checked the fuses and connections seem clean so I jumped directly from the battery to pin 12 on the circuit board, turn the key to 1 and got the fuel pump buzz, turned off and back on again got the fuel pump to work. What do you guys think should be my next step? I planning to get on it early tomorrow and start chasing the wiring but hope someone here might help me narrow down the possibilities. Plan to remove the circuit board, turn it over and check the connections and double check the grounds and then check continuity from the brain, then work my way to the inside fuse panel and wherever else the electrons are circulated before reaching the fuel pump. As always THANK you guys for all you do to help the 914 live on!!! Brady |
JeffBowlsby |
Sep 22 2018, 08:58 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The ECU would be the last thing to suspect, they are very reliable. I have seen a bad one but very infrequently. I have the equipment to check its functions, but check other things first.
How does your harness look? New, old? Terminals nice and clean or corroded? Still suspect your relay board given its connection to the fuel pump circuitry. Did you run a full continuity check on all its circuits? |
Minerva's 914 |
Sep 22 2018, 09:46 PM
The ECU would be the last thing to suspect, they are very reliable. I have seen a bad one but very infrequently. I have the equipment to check its functions, but check other things first. How does your harness look? New, old? Terminals nice and clean or corroded? Still suspect your relay board given its connection to the fuel pump circuitry. Did you run a full continuity check on all its circuits? Harness looks good, no signs of corrosion, breakage nor browning from heat. I only visually checked the circuit board but did jump 12v to 86 pin on the relay while plugged in as described above and ran 12v jumper to pin 12 on the circuit board both of which buzzed the pump. Checked resistance between contact 19 on the ECU harness and relay plate terminal III, the ECU control line for the fuel pump, read 0.24 ohms.Checked voltage on 16 and 24 ECU harness got 12.54 volts on both. So as I'm writing this I realize that your thinking makes sense about looking closer at the circuit board, although it is strange that unplugging and plugging back the ECU harness would make and break the connection to the pump operation and would the curium board effect the running of the ignition since when the pump was running the car would not run. Thanks for your help |
Lo-Fi Version | Time is now: 16th May 2024 - 11:20 AM |
