400K transmission woes, Failure on the way home from Okteenerfest |
ClayPerrine |
Sep 22 2018, 01:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
After leaving the hotel in Vicksburg on the second day of the way home, the 400K transmission in Betty's car let go. It was spectacular. It looked like the race cars you see on TV blowing an engine, a HUGE cloud of smoke behind it. We pulled off and looked underneath. The input shaft seal on the trans let go.
Well, this morning I pulled the trans and disassembled it. It is more than just the seal.... The input shaft bearing failed. There is damage to the threads on the input shaft so I have to replace it. What isn't pictured is the damage to the ring and pinion when something went between them. So I have to replace the pair too. Here's what it's going to take. Input shaft Ring gear Pinion gear input shaft bearing Input shaft seal Gasket kit. And time setting up the ring and pinion in this trans case. Yes, I will be reusing the trans case, tail cover, and as much of the original trans as possible. Betty wants it to be as original as possible. I have all the parts, bearings and seals already here, so tomorrow I get to clean and reassemble the gear stack. I have a differential and matched pinion shaft, and plenty of input shafts, so I am all set. It is just a bunch of work that I wasn't planning on. (IMG:style_emoticons/default/smash.gif) |
ClayPerrine |
Oct 14 2018, 04:43 PM
Finished up Betty's transmission today. With all the travelling about the country, I have not had time to get out to the garage to finish it. All new guts in the same old case. Bearings, syncros, differental, ring and pinion, everything but the output flanges were replaced.
Got done about 4:15. Took it for a short test drive, and it ran and shifted great. At 400K, the old trans was whining a bit. The rebuild fixed the whine, and it fixed the worn second gear syncro. Off for another trip tonight. This was is to Denver at 8:30 for business. I am getting tired of travelling so much. Okteenerfest, Rennsport, Hallett club race, now Denver. Too bad we don't have a dragging ass smiley. |
worn |
Oct 14 2018, 05:36 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
double post
Lo-Fi Version | Time is now: 17th May 2024 - 08:13 PM |
