Mallory Unilite Testing, Exploring an out-of-car test idea.... |
jim_hoyland |
Sep 23 2018, 06:12 AM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Mallory Unilite Optical module PN# 605.
Attached thumbnail(s) |
jim_hoyland |
Sep 23 2018, 06:22 AM
I want to test some optical modules I have by connecting my spare coil to a 12v power source; then connect the unlit module; red to coil +, green to coil - and brown to battery power source ground. Then follow the factory test procedure ( see next post )
So, am I overlooking anything ? Any ideas will be appreciated. |
jim_hoyland |
Sep 23 2018, 06:34 AM
Here is the factory instruction,
1. Remove the cap and rotor. Turn ignition ON and test voltage at the NEGATIVE side of the coil. ( black lead of meter to ground and red lead of meter to coil NEGATIVE POST). Voltage should read 12 volts. 2. If better voltage is present, place a credit cars, drivers license, business card or sillier and block the photo optics of the module. The voltage should drop to 2 volts of less ( 1-2 volts). If this test is positive, then module is working. 3. If the test results are as follows: a. Voltage does not drop, module is open and must be replaced b. Voltage stays below 3 volts, The module has been spiked by high voltage c. Voltage only drops to 2-4 volts, weak spark is being produced |
jim_hoyland |
Sep 25 2018, 04:37 AM
Anyone ? I
yeahmag |
Sep 25 2018, 09:31 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I run a Unilite and this test is basic. I have had a failure when running that is not picked up by the simple go/no go test. It will show you of the module has completely failed or not. Run the power conditioning module in front of the optical trigger!
jim_hoyland |
Sep 25 2018, 01:01 PM
I run a Unilite and this test is basic. I have had a failure when running that is not picked up by the simple go/no go test. It will show you of the module has completely failed or not. Run the power conditioning module in front of the optical trigger! Thanks Aaron, If you have a module that had failed, would you mind sending it to me. I'm doing some experimenting.... I also had the Intermediate type of failure, twice ! And, I have a spare in the garage......just in case |
Lo-Fi Version | Time is now: 23rd April 2024 - 05:02 PM |
