| Tdskip |
Feb 24 2022, 07:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Great discussion.
If the look cooler works without a fan wouldn’t a more conventional radiator work without one? OR, if going to trouble to mount a conventional radiator the fan is a while-we-are-at-it thing anyway? |
| mepstein |
Feb 24 2022, 10:39 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,007 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Great discussion. If the look cooler works without a fan wouldn’t a more conventional radiator work without one? OR, if going to trouble to mount a conventional radiator the fan is a while-we-are-at-it thing anyway? I think it depends on how much cooling you want and how much stop and go traffic you might run into. My thought is if you can fit a loop cooler in that spot then why not go with a small modern cooler and a low profile fan pack. A loop cooler is going to do very little if you are sitting in traffic on a hot summer day. Especially when the blacktop is radiating 140 degrees up into the rear quarter. |
| horizontally-opposed |
Feb 24 2022, 12:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Great discussion. If the look cooler works without a fan wouldn’t a more conventional radiator work without one? OR, if going to trouble to mount a conventional radiator the fan is a while-we-are-at-it thing anyway? Have seen a few ways to add an external oil cooler on a 914, including a center front, paired front coolers at the corners, under the rear trunk floor, and now Perry's insanely clean & cool install. All of these were radiator style, I think? Have thought about a loop cooler for the front fenders—narrower than the 911 due to the car's design but doubled with two lines going across whether inside or outside of the front trunk. Even if the loops are very small, hard lines would add a lot of oil (and surface area) on the way forward, through both loops, the connections across the car, and the way back. I've never thought about, much less seen, a 911 loop cooler in a 914's rear fender, or that it might fit. Can see why Perry's setup would need a fan, as there might not be much if any airflow in there without a vent or ducting. Suspect the area above/behind the rear wheels sees a lot more air circulating than the area in front of the rear wheel, even if it isn't nearly as much as a front cooler would see. |
| Tdskip |
Feb 24 2022, 03:09 PM
I think it depends on how much cooling you want and how much stop and go traffic you might run into. My thought is if you can fit a loop cooler in that spot then why not go with a small modern cooler and a low profile fan pack. A loop cooler is going to do very little if you are sitting in traffic on a hot summer day. Especially when the blacktop is radiating 140 degrees up into the rear quarter. Makes sense - delta of effort is small enough to just include a fan. Thanks |
| willieg |
Jun 6 2022, 07:40 AM
Member ![]() ![]() Group: Members Posts: 147 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California
Perry
Great documentation. Thank you. |
| stevesc_us |
Jun 6 2022, 08:28 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 12-February 06 From: Redwood City, CA Member No.: 5,569 |
| JmuRiz |
Jun 6 2022, 10:18 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,655 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Always wondered where that car ended up. Does it have an on-cooler thermostat or a separate one?
I'm still hemming/hawing about where to put my cooler for my 2.8 6-conversion. Under rear trunk, front cooler....or that engine lid one. I have a GT style lid that might work with the dual oil cooler fans (IMG:style_emoticons/default/idea.gif) |
| stevesc_us |
Jun 6 2022, 10:44 AM
She is now owned by Freeman Thomas, who as you may be aware is a well-known car designer that worked at the Zuffenhausen factory in the 1980's and was the original designer of the Audi TT. The best part of this tid bit of history is that his inspiration for the TT was none other than the 914-6! Couldn't have asked for a more worthy caretaker to carry on the stewardship of cherishing my sweet 6 after my 25 years of ownership.
| vitamin914 |
Jun 6 2022, 12:37 PM
Member ![]() ![]() Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada
Although it seems we may spend more time under our cars than driving them the problem I am running into with my Aux. oil cooler location is ROAD CRUD.
The tires kick up everything on the road, water, sand, stones, bubble gum. Locating in the wheel well means the fan motor is going to be destroyed a lot quicker and the fins are going to be fouled up. I just yanked the failed horn the PO put in the front wheel well directly ahead of the front tire. A pound of dirt must have fallen out it when it hit the ground. Best place for the oil cooler has to be the front or under the engine lid, worst anywhere near a tire. My oil cooler is almost behind the rear wheel and I am forever cleaning it. I don't need another job of relocating it either. Maybe an angled Lexan deflector to keep it cleaner? |
| 914werke |
Jun 6 2022, 05:49 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,800 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
I like that loop cooler but at nearly $600 Im sure you can get a decent traditional cooler, fan & lines for that!
Oh & kudo's Perry, sano setup! |
| colingreene |
Jun 6 2022, 07:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Not that anyone asked, This is what i did for my 2258cc motor that always ran on the hot side.
I used a Setrab Oil cooler sandwich adaptor with a thermostat in it to some -12 lines. the lines run out and around the motor back to the cooler. the fans are controlled by a thermostatic switch to keep oil temps regulated. I made some mounts to hang it off the back of the tin and the front of the trans mount so when I remove the motor it all comes out as one part. Attached image(s)
| Tdskip |
Jun 6 2022, 10:53 PM
Thanks for posting that @colingreene
Lo-Fi Version | Time is now: 22nd November 2026 - 06:50 AM |
