Broke down in Bakersfield Ca, Need side shift rod for side shift or welding shop |
MJHanna |
Sep 25 2018, 10:13 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
On way to Rennsport
Weld back by coupler going into transmission broke the weld needed another rod or a welding shop in area Thanks Mark |
Maltese Falcon |
Sep 25 2018, 10:48 PM
Advanced Member Group: Members Posts: 4,629 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
A great reputable shop
Born Vintage Hot Rods, owner is Kamaka (from Maui) 661.873.4722, 2459 Fruitvale/ Bakersfield. All types of welding, Fab + more than likely has the right od tube if you need a new one. I know about his custom builds ( and a SEMA build win as well) via instagram... good guy indeed (IMG:style_emoticons/default/welder.gif) I'd fix it for you...but at Rennsport 6 (IMG:style_emoticons/default/smile.gif) |
MJHanna |
Sep 25 2018, 10:52 PM
A great reputable shop Born Vintage Hot Rods, owner is Kamaka (from Maui) 661.873.4722, 2459 Fruitvale/ Bakersfield. All types of welding, Fab + more than likely has the right od tube if you need a new one. I know about his custom builds ( and a SEMA build win as well) via instagram... good guy indeed (IMG:style_emoticons/default/welder.gif) I'd fix it for you...but at Rennsport 6 (IMG:style_emoticons/default/smile.gif) Thanks for the information I hope to see you tomorrow at Rennsport |
troth |
Sep 25 2018, 10:57 PM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
On way to Rennsport Weld back by coupler going into transmission broke the weld needed another rod or a welding shop in area Thanks Mark I think my dad will be driving by you guys late tomorrow or early Thursday. They are in Flagstaff now. The itinerary has them driving through Grand Canyon to Hoover Dam and then to Paso Robles, CA for the night. The rough itinerary has them departing Hoover Dam at 4:15 PM. So would be driving by you guys around 9 PM. Don't have the rod in the spares stash, but if somebody can come up with one along route, they could deliver it to you along with tools to replace it. |
pete000 |
Sep 25 2018, 11:38 PM
Call Bruce Stone, he is in Riverside...
MJHanna |
Sep 26 2018, 12:15 AM
I’m going to pull it in the morning and go sit on Born vintage door step and beg him to fix it. He is about 13 min from where I’m staying
Mikey914 |
Sep 26 2018, 01:19 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Let me know if we need to expedite new bushings to you. You may be able to re use the ones there if they are not crunchy. You will know when you go to remove them.
bdstone914 |
Sep 26 2018, 04:23 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I’m going to pull it in the morning and go sit on Born vintage door step and beg him to fix it. He is about 13 min from where I’m staying I would have a complete rod. Not clear as to what broke. Remove the bushings before welding. Requires a Visa to press out the pin. Call me at Pelican if needed 888 280 7799 or my cell 951 536 7478 Bruce |
MJHanna |
Sep 26 2018, 06:24 AM
Not the best picture but here is the end of the tube that attaches at the transmission
Attached thumbnail(s) |
76-914 |
Sep 26 2018, 07:40 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm 30 S of you with transportation and a lift if needed. I can drive you to Bruce's, grab a new rod and have you going quickly. LMK here. I'll watch this thread this morning in case. Kent
bdstone914 |
Sep 26 2018, 08:14 AM
I'm 30 S of you with transportation and a lift if needed. I can drive you to Bruce's, grab a new rod and have you going quickly. LMK here. I'll watch this thread this morning in case. Kent If you get is welded it looks like the solid rod is loose from the tube. There is a clocking of that shaft with the hole to position it to the tube. If it is off nothing will line up. I have a jig that I use to set the shaft to tube orientation. Those cone screws are supposed to be replaced. At least clean them and use some locktite Kent. He is in Bakersfield. Are you heading that way? Call me at 951 536 7478 if you want a rod. We can work out payment later. Bruce @76-914 @MJHanna |
Chi-town |
Sep 26 2018, 08:25 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Oops, forgot my u-joint is wasted (IMG:style_emoticons/default/headbang.gif)
mmichalik |
Sep 26 2018, 08:41 AM
MikeM Group: Members Posts: 688 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
It's too bad we don't have "like" buttons here. It's great to see people come together and help each other out.
Nice job, gentlemen! |
76-914 |
Sep 26 2018, 08:48 AM
I'm 30 S of you with transportation and a lift if needed. I can drive you to Bruce's, grab a new rod and have you going quickly. LMK here. I'll watch this thread this morning in case. Kent If you get is welded it looks like the solid rod is loose from the tube. There is a clocking of that shaft with the hole to position it to the tube. If it is off nothing will line up. I have a jig that I use to set the shaft to tube orientation. Those cone screws are supposed to be replaced. At least clean them and use some locktite Kent. He is in Bakersfield. Are you heading that way? Call me at 951 536 7478 if you want a rod. We can work out payment later. Bruce @76-914 @MJHanna @bdstone914 hadn't planned on it but if he needs it I thought I'd run by your place on the way up. Besides, I'm semi-retired so time on my hands. (IMG:style_emoticons/default/beerchug.gif) |
EdwardBlume |
Sep 26 2018, 09:11 AM
Looks like the right guys are involved.
If you get it temp fixed but need a longer term part, you can get this in Pleasanton or I can bring it to RRVI. No cost. Attached thumbnail(s) |
EdwardBlume |
Sep 26 2018, 09:15 AM
Better pict
MJHanna |
Sep 26 2018, 10:46 AM
Got fixed !!! Great guys at the shop they welded it and sleeved it
Shifts great I’m back on the road to Rennsport That’s to everyone for all your help Mark |
Ferg |
Sep 26 2018, 11:05 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
76-914 |
Sep 26 2018, 11:35 AM
Boogie, boogie before they drink all the Beer! (IMG:style_emoticons/default/beerchug.gif)
ConeDodger |
Sep 26 2018, 07:24 PM
Apex killer! Group: Members Posts: 23,552 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Hey, I’m just sayin... slits would have had him fixed but too drunk to drive last night. (IMG:style_emoticons/default/evilgrin.gif)
Lo-Fi Version | Time is now: 19th April 2024 - 09:31 PM |
