The right way to close up a welding project, Primer? Weld Through? Weld putty? POR15? |
ctc911ctc |
Sep 26 2018, 05:41 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
I am looking for definitive guidance and perhaps a pointer to a thread on this topic. We have finished all of the welding on metal that was primed with weld-through. We will now grind the welds. Is this the correct thing to do in this order? Zinc Primer Weld Weld some more plug up the holes with weld or epoxy (screw holes and small gaps) Grind the weld and expoy smooth (smoother) Treat the welds with 3M weld putty spray another coat of Primer Coat with POR15 Do I have this right? Flame ON!!!! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:01 PM |
