Side marker light, How is it held on |
tmc914 |
Sep 30 2018, 01:12 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
Below is a picture of the front and back of my side marker light. What kind of fastener is holding this light to the metal? It looks like some sort of white plastic push rivet.Maybe not a push rivet but it is loose and only spins when I try to remove it. Probably not from the factory. I plan on replacing the worn out rubber and will most likely destroy what is holding this on to remove it. What should I use to hold the marker light onto the car?
Mikey914 |
Sep 30 2018, 01:28 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Plastic clips.
Also a really good time to replace the seal. May be able to reuse if not I have them here - https://900designs.zoeysite.com/side-marker-plastic-clip Looks like you may want to replace the boot while you are there too. https://900designs.zoeysite.com/front-turn-...al-grommet-boot Attached thumbnail(s) |
Larmo63 |
Sep 30 2018, 01:30 PM
They can be re-installed with nuts and bolts......
Mikey914 |
Sep 30 2018, 01:31 PM
They can be installed with plastic pop rivets too. readily available at HD
Lo-Fi Version | Time is now: 17th May 2024 - 03:39 AM |
