73 2.0 Hesitates when cold.. |
schmidder |
Oct 1 2018, 12:07 PM
Newbie Group: Members Posts: 13 Joined: 24-April 17 From: Folsom, CA Member No.: 21,045 Region Association: Northern California |
Not a fuel injection expert at all. I have done some research and have read quite a bit, have a specific issue I am having, wondering if folks would point me in the right direction as to what might be the issue with the following symptoms:
1973 Fuel Injected 2.0 Car runs great once the motor is warm At start up, will hunt for idle, but not always. If it hunts, goes up to 1300 and down to 200. ( live in Nor Cal, so cold means 50 to 75F) If I don't let the car idle and warm for 5+ minutes, even on a 90F day, when I go to drive, it hesitates badly between 2-3000 RPM and sometimes will just die Will start back up just fine and once warm, issue goes away Car will also hesitate if I am in cruising at 3k rpm, take my foot off and then back on, this will happen warm or cold. Gas mileage is good, otherwise car runs terrific, good power. I don't mind letting the car warm up and am not looking to just jump in a take off and hammer, just wondering if this is a common issue. Thanks for your help in advance... Erik |
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 AM |
