Are the Pertonix curves correct? |
Tdskip |
Oct 2 2018, 09:14 AM
Advanced Member Group: Members Posts: 3,674 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Didn’t want to hijack another thread so I thought I’d ask on a new one.
Are these units drop right in? Curve correct? Thanks! |
bmtrnavsky |
Oct 2 2018, 09:19 AM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
Mine just replaced the points and worked right out of the box.
eitnurg |
Oct 2 2018, 09:34 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
The advance mechanism is in the dizzy itself? There are no ‘curves’ in the Pertronix unit, it just replaces the points?
jdamiano |
Oct 2 2018, 09:43 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
If you’re asking about the distributor they sell I have one in my 2x 40idf carb 2.0 and it works fine. Dropped right in, set the timing and good to go.
Mark Henry |
Oct 2 2018, 09:47 AM
The advance mechanism is in the dizzy itself? There are no ‘curves’ in the Pertronix unit, it just replaces the points? Yes, pertronix does nothing to the advance curve. Only a box like a MSD 6 programmable or other electronic programmable systems can run an advance curve on a dizzy this way. With these systems you have to lock out the dizzy's mechanical advance. |
Mark Henry |
Oct 2 2018, 09:58 AM
A quick note for newbies, changing to pertronix will change the initial timing setting and you will have to break out the timing light. But you have to do this even when replacing regular points.
Timing the engine and the dizzy advance curve are two seperate things. |
Tdskip |
Oct 2 2018, 10:20 AM
Hi guys - inadequately precise question on my part.
I was asking about the drop in distributor. Oops! |
jdamiano |
Oct 2 2018, 12:25 PM
76-914 |
Oct 2 2018, 03:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hi guys - inadequately precise question on my part. I was asking about the drop in distributor. Oops! Call them and ask. They are super helpful. They may need to call you back later. I have a complete Petronix dizzy (Flamethrower series) on the V8 car I'm doing. Great product but as mentioned above they need to know what it's going on. Be sure to buy the req'd matching coil if you go that route. (IMG:style_emoticons/default/beerchug.gif) |
garm |
Oct 2 2018, 08:00 PM
Newbie Group: Members Posts: 21 Joined: 23-June 18 From: Chatsworth CA Member No.: 22,247 Region Association: Southern California |
I was looking at these just today for my 2.7 swap. Couldn't figure out which one would be correct for my build, so I will give them a call.
Also looking at the 123 products; they have a bluetooth dizzy you can program from your smartphone. I assume you'd be programming the curve, right? Any thoughts Pertronix vs. 123? |
Mark Henry |
Oct 3 2018, 05:45 AM
No clue on the advance curve and it looks like it's not adjustable, so good or bad your stuck with it.
123 is fully adjustable from bluetooth phone or tab. |
Red72 |
Jan 19 2019, 12:46 PM
Newbie Group: Members Posts: 25 Joined: 26-January 15 From: Simcoe, Ontario Member No.: 18,358 Region Association: Canada |
So with the Pertronix Igniter II, they have adjustable advance curves with springs and limiters. They advertise something like 78 different possible curve combinations with these parts...has anyone run across a complete listing? Sounds like there's plenty of potential to customize, just trying to figure out how.
With the 'stock' settings you can get about 24 degrees of advance at 3500, but if you want 27 degrees, and static of 5 on the 1.7 engine, then you don't want the 24 degrees total advance... Steve |
Lo-Fi Version | Time is now: 29th March 2024 - 01:23 AM |
