Fast idle |
Fast idle |
adolimpio |
Oct 3 2018, 05:35 PM
Art Group: Members Posts: 181 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I've been struggling to set the idle on my stock 2.0 DJet with no success.
With the idle fuel mixture set to max, the idle screw on the throttle body turned all the way in and the engine warm, it idles at about 1500. If I reduce the idle fuel mixture to get the idle down to 900, the idle becomes unstable, seeking between very low RPMs and 900. Everything is stock and otherwise runs absolutely great. I've check for the obvious vacuum leaks, plugging every vacuum line except MPS with no effect. This should have eliminated the lines, aux air valve and decel valve. Everything is adjusted to stock: Valves - .006 and .008 Fuel pressure - 29psi Timing - 27 degrees TPS set properly and circuit board looks to be in good shape Any thoughts are appreciated! |
76-914 |
Oct 3 2018, 06:22 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did you check the breather gasket, plenum, injector seals? If so, I’d suspect the MPS. I had one drive me now nuts before. Got a spare you can throw on it.
JSA |
Oct 3 2018, 06:23 PM
Newbie Group: Members Posts: 9 Joined: 2-October 18 From: Osawatomie,Ks. Member No.: 22,538 Region Association: None |
I've been struggling to set the idle on my stock 2.0 DJet with no success. With the idle fuel mixture set to max, the idle screw on the throttle body turned all the way in and the engine warm, it idles at about 1500. If I reduce the idle fuel mixture to get the idle down to 900, the idle becomes unstable, seeking between very low RPMs and 900. Everything is stock and otherwise runs absolutely great. I've check for the obvious vacuum leaks, plugging every vacuum line except MPS with no effect. This should have eliminated the lines, aux air valve and decel valve. Everything is adjusted to stock: Valves - .006 and .008 Fuel pressure - 29psi Timing - 27 degrees TPS set properly and circuit board looks to be in good shape Any thoughts are appreciated! Possibly injector seals? Just a thought. |
adolimpio |
Oct 3 2018, 06:47 PM
Injector seals are new and all gaskets look good.
I've sprayed carb cleaner on areas that could leak. I've found that if there's a leak this will cause the engine to stumble a bit. There were no signs of leaks. Not sure how to test the MPS. Can't block the line without affecting engine running. I've sucked on the port and the diaphragm seems to be good. No sign of a leak. Also, it runs great other than at idle. |
JSA |
Oct 3 2018, 06:57 PM
Injector seals are new and all gaskets look good. I've sprayed carb cleaner on areas that could leak. I've found that if there's a leak this will cause the engine to stumble a bit. There were no signs of leaks. Not sure how to test the MPS. Can't block the line without affecting engine running. I've sucked on the port and the diaphragm seems to be good. No sign of a leak. Also, it runs great other than at idle. Good battery,grounds? Things seem to be pointing back to the TPS |
adolimpio |
Oct 3 2018, 07:14 PM
Battery ground cable is solid, and transmission ground strap is new.
I,ve tried two throttle bodies, both of which seem to have a good TPS. As I understand it, the throttle mixture adjustment would not have any affect if the TPS was not properly indicating that throttle was at idle position. |
JSA |
Oct 3 2018, 07:44 PM
Battery ground cable is solid, and transmission ground strap is new. I,ve tried two throttle bodies, both of which seem to have a good TPS. As I understand it, the throttle mixture adjustment would not have any affect if the TPS was not properly indicating that throttle was at idle position. Your getting close.I would get a hand operated vacuum pump and check the MPS just for general principles.Its a good old system it just has old age problems like me,Ha! |
914_teener |
Oct 3 2018, 08:11 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Have you cleaned then dizzy advance plate?
Assuming you have a stock distrubutor. Also check the two advance and retard cans for leaking diaphrams. Not sure what year D-jet....you didn.t say.....all D-jet compments should match for that year.......as they are different. |
adolimpio |
Oct 3 2018, 08:22 PM
Distributor is stock, and advance plate moves nicely.
I've plugged both vacuum lines so that should eliminate a diaphragm problem, correct? |
cgnj |
Oct 4 2018, 05:26 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I had a similar problem. Turned out to be a cracked phenolic intake gasket.
Carlos |
saigon71 |
Oct 4 2018, 06:09 AM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Injector seals are new and all gaskets look good. I've sprayed carb cleaner on areas that could leak. I've found that if there's a leak this will cause the engine to stumble a bit. There were no signs of leaks. Not sure how to test the MPS. Can't block the line without affecting engine running. I've sucked on the port and the diaphragm seems to be good. No sign of a leak. Also, it runs great other than at idle. This site lists bench testing procedures for the MPS anlong with tons of other helpful info on D-jet: https://members.rennlist.com/pbanders/DJetParts.htm |
GregAmy |
Oct 4 2018, 06:19 AM
Advanced Member Group: Members Posts: 2,305 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I chased D-Jet problems for two seasons before I finally capitulated and let Chris Foley rebuild my MPS with a new diaphragm and modify it to be tunable.
I was a religious experience. All my D-Jet problems have magically gone away*. I have gone from "I hate this friggin thing I'm installing carbs" to "this thing drives great." The MPS diaphragms are mechanical plates with a limited lifetime. It's worth the expense to have them rebuilt. *I do have one annoying issue, but I think it's the nature of the beast. Car starts and runs fine cold but then as the heads get hot/warm, but before the engine is fully warmed up, the computer dials down the fuel and it runs too lean and won't idle smoothly. But once I get 5 minutes on the engine and it's fully hot the engine idles like a charm. I've given consideration to putting in a switchable or time-relayed resistor on the CHT, but haven't garnered the motivation yet... |
Olympic 914 |
Oct 4 2018, 06:39 AM
Group: Members Posts: 1,671 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Another place to look is at the plenum. I discovered a leak in one after chasing a high idle. the support tubes between the top and bottom leaked. I only found it by dunking it in a sink full of water and putting a couple pounds of air to it.
JB Weld cured it. |
BeatNavy |
Oct 4 2018, 06:44 AM
Two most likely suspects on D-Jet cars are timing over-advanced or vacuum leak somewhere. From Anders' site, here's a list of possible vacuum leak problem areas. The plenum, in particular, is a hard one to detect. They are prone to cracks at the support posts, which are hard to see.
1. Intake runner-to-head gasket/spacer 2. Injector seals 3. Intake runner boots 4. Air plenum (e.g. cracks or rust holes) 5. Throttle body gasket 6. Throttle body shaft (worn body or shaft) 7. Distributor vacuum adv/ret cell 8. Auxiliary air regulator (stuck open or leaky) 9. Deceleration valve 10. Manifold pressure sensor 11. Vacuum hose cracks 12. Cold-start valve gasket to plenum Go through these one by one as best you can and check 'em off. Edit: Olympic just beat me to it (IMG:style_emoticons/default/smile.gif) |
76-914 |
Oct 4 2018, 08:45 AM
Once, I had new injector seals installed therefor I assumed that the seals couldn't be the problem. Then one day I noticed #2 injector was at a bit of an angle. I loosed the clamp, straightened the injector, retightened and that was it. I too had sprayed starter fluid in that area but missed it. Just saying...........Also, I forgot to mention the throttle body shaft. Well known culprit, too! (IMG:style_emoticons/default/beerchug.gif)
adolimpio |
Oct 4 2018, 10:13 AM
I plan to get a vacuum pump over the weekend to test the MPS.
I'll also inspect the plenum carefully, and may pull it out, pressurize and dunk it. I've tried two throttle bodies, one of which looks new and has virtually no tracks on the TPS board. Thanks for all the suggestions! |
adolimpio |
Oct 4 2018, 02:39 PM
Another place to look is at the plenum. I discovered a leak in one after chasing a high idle. the support tubes between the top and bottom leaked. I only found it by dunking it in a sink full of water and putting a couple pounds of air to it. JB Weld cured it. Bingo - a crack around the support tube right where you showed in your picture. I guess I need to pull the plenum to check the undersides as well. Thank you very much! I would not have considered a crack in that area since there appears to be no stress, but then again, these things are 45 years old! |
Lo-Fi Version | Time is now: 21st May 2024 - 03:07 AM |
