CV Joints, Available again? |
bbrock |
Oct 4 2018, 07:21 AM
I just plugged the OEM CV joint part # into Sunset Porsche's web site and got a hit ($73.64). So these are available again? (IMG:style_emoticons/default/confused24.gif)
https://www.sunsetporscheparts.com/oem-part...int-91433202903 EDIT: Don't Order these! What you get are 25-spline joints which appears to be the part for a 914-6. They won't fit on /4 axles. For more detail, see http://www.914world.com/bbs2/index.php?s=&...t&p=2698908 |
mb911 |
Dec 5 2018, 06:54 AM
914 Guru Group: Members Posts: 6,852 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive..
Mark Henry |
Jan 2 2019, 01:23 PM
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive.. BTDT Not quite that easy, the CV material is hard as hell. Might be easier to send it to a crank grinder and have them grind the recess in. |
ChrisFoley |
Jan 2 2019, 02:45 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive.. BTDT Not quite that easy, the CV material is hard as hell. Might be easier to send it to a crank grinder and have them grind the recess in. A sharp carbide tool bit will cut them just fine. The body is only moderately hard, and the ball track area is flame hardened. |
rgalla9146 |
Jan 3 2019, 01:34 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive.. BTDT Not quite that easy, the CV material is hard as hell. Might be easier to send it to a crank grinder and have them grind the recess in. A sharp carbide tool bit will cut them just fine. The body is only moderately hard, and the ball track area is flame hardened. Today I assembled driveshafts with four of the modified Type 1 joints that Chris marketed in the past. The modifications were done beautifully. They're going in my project car with a fresh 2.0 6 cyl. I hope the reports of early wear prove wrong. Has anyone ordered or purchased the available 914 6 assemblies ? |
914_teener |
Jan 3 2019, 03:41 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive.. BTDT Not quite that easy, the CV material is hard as hell. Might be easier to send it to a crank grinder and have them grind the recess in. A sharp carbide tool bit will cut them just fine. The body is only moderately hard, and the ball track area is flame hardened. Today I assembled driveshafts with four of the modified Type 1 joints that Chris marketed in the past. The modifications were done beautifully. They're going in my project car with a fresh 2.0 6 cyl. I hope the reports of early wear prove wrong. Has anyone ordered or purchased the available 914 6 assemblies ? I don't know if there is any "early" wear or not. I haven't taken them apart yet. I can only report that without the recess of the gasket they will sling grease without sealing them really well. I could be that the "early" wear is caused by the grease being slung out....causing early wear. Since you have a set by Chris with the recess....should be good to go...don't look back and drive it like you stole it. |
brant |
Jan 3 2019, 05:37 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I have decided I am just going to use lobro type 1 CVS and just machine the gasket area .. It will be pretty straight forward and fairly inexpensive.. BTDT Not quite that easy, the CV material is hard as hell. Might be easier to send it to a crank grinder and have them grind the recess in. A sharp carbide tool bit will cut them just fine. The body is only moderately hard, and the ball track area is flame hardened. Today I assembled driveshafts with four of the modified Type 1 joints that Chris marketed in the past. The modifications were done beautifully. They're going in my project car with a fresh 2.0 6 cyl. I hope the reports of early wear prove wrong. Has anyone ordered or purchased the available 914 6 assemblies ? I don't know if there is any "early" wear or not. I haven't taken them apart yet. I can only report that without the recess of the gasket they will sling grease without sealing them really well. I could be that the "early" wear is caused by the grease being slung out....causing early wear. Since you have a set by Chris with the recess....should be good to go...don't look back and drive it like you stole it. I’m having early wear out Not a grease problem Machined Sealed And twice vw the wear of stock in a hard use situation (so far) Fresh grease frequently |
Lo-Fi Version | Time is now: 18th May 2024 - 07:55 AM |
