CV Joints, Available again? |
bbrock |
Oct 4 2018, 07:21 AM
I just plugged the OEM CV joint part # into Sunset Porsche's web site and got a hit ($73.64). So these are available again? (IMG:style_emoticons/default/confused24.gif)
https://www.sunsetporscheparts.com/oem-part...int-91433202903 EDIT: Don't Order these! What you get are 25-spline joints which appears to be the part for a 914-6. They won't fit on /4 axles. For more detail, see http://www.914world.com/bbs2/index.php?s=&...t&p=2698908 |
brant |
Oct 12 2018, 11:14 AM
914 Wizard Group: Members Posts: 11,619 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
just one person's experience
I put new type 1 joints (x4) on the racecar. granted it might be an extreme environment but with limited hours of use... 20? I noticed much more wear than original joints so this could be due to my application but I am also harboring the belief that the type 1 (modified) joints do not hold up nearly as well as original specification joints used to. I'm not a fan I'm going to upgrade to 944 CV's and add real weight to the racecar in exchange for longevity.... and I hate adding weight! |
914_teener |
Oct 12 2018, 02:16 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
just one person's experience I put new type 1 joints (x4) on the racecar. granted it might be an extreme environment but with limited hours of use... 20? I noticed much more wear than original joints so this could be due to my application but I am also harboring the belief that the type 1 (modified) joints do not hold up nearly as well as original specification joints used to. I'm not a fan I'm going to upgrade to 944 CV's and add real weight to the racecar in exchange for longevity.... and I hate adding weight! (IMG:style_emoticons/default/agree.gif) I have the same opinion after about 4 years since replacement. MAYBE 10k Miles on them? I haven't inspected them yet....just a mess I'd not get into at the moment. |
76-914 |
Dec 5 2018, 10:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
just one person's experience I put new type 1 joints (x4) on the racecar. granted it might be an extreme environment but with limited hours of use... 20? I noticed much more wear than original joints so this could be due to my application but I am also harboring the belief that the type 1 (modified) joints do not hold up nearly as well as original specification joints used to. I'm not a fan I'm going to upgrade to 944 CV's and add real weight to the racecar in exchange for longevity.... and I hate adding weight! (IMG:style_emoticons/default/agree.gif) I have the same opinion after about 4 years since replacement. MAYBE 10k Miles on them? I haven't inspected them yet....just a mess I'd not get into at the moment. @914 teener are those the ones I. sold you when I converted to Subaru? If so, they didn't have more than 600 miles on them, IIRC. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Dec 5 2018, 12:00 PM
just one person's experience I put new type 1 joints (x4) on the racecar. granted it might be an extreme environment but with limited hours of use... 20? I noticed much more wear than original joints so this could be due to my application but I am also harboring the belief that the type 1 (modified) joints do not hold up nearly as well as original specification joints used to. I'm not a fan I'm going to upgrade to 944 CV's and add real weight to the racecar in exchange for longevity.... and I hate adding weight! (IMG:style_emoticons/default/agree.gif) I have the same opinion after about 4 years since replacement. MAYBE 10k Miles on them? I haven't inspected them yet....just a mess I'd not get into at the moment. @914 teener are those the ones I. sold you when I converted to Subaru? If so, they didn't have more than 600 miles on them, IIRC. (IMG:style_emoticons/default/beerchug.gif) Yes they are. I haven't inspected them yet. I may though if I keep the car for now. Have a spare trans and I may swap it in if I don't sell the car and I'll do it then. I've probably put those miles on them Kent since I got them from you. I'll assume they were Lobro's? One thing for sure with the type 1's I've experienced is they will sling grease if you don't have the gasket recess that Foley used to sell. It is a real pain but I got mine to finally seal with some high temp silly cone. I had to clean the faces really well and when you bolt up the joint it is near impossible to keep the joint and the flange grease free when installing them. AND if you use the gasket without the recess the bolts will back out. So if I'd to go that way again I'd definitely get a set with the recess. My two cents. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:49 AM |
