CV Joints, Available again? |
bbrock |
Oct 4 2018, 07:21 AM
I just plugged the OEM CV joint part # into Sunset Porsche's web site and got a hit ($73.64). So these are available again? (IMG:style_emoticons/default/confused24.gif)
https://www.sunsetporscheparts.com/oem-part...int-91433202903 EDIT: Don't Order these! What you get are 25-spline joints which appears to be the part for a 914-6. They won't fit on /4 axles. For more detail, see http://www.914world.com/bbs2/index.php?s=&...t&p=2698908 |
rgalla9146 |
Jan 4 2019, 03:57 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I just learned something interesting.
I have a 914 6 CV that's missing it's balls. (no rude comments please) So why not substitute some from a new modified Type 1 that I have on hand ? Cheap fix right ? Guess what ?.... the balls are bigger... and not in the direction that you'd guess. The balls in a VW CV are 17.44mm diameter. In the 914 6 they're 15.84 I'm no engineer but that doesn't seem right. You'll be comforted to know that 914 and 914 6 CVs have the same size balls. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 11:37 AM |
