914 Hayabusa Build |
eatpez |
Oct 4 2018, 11:31 PM
Newbie Group: Members Posts: 18 Joined: 4-October 18 From: Michigan Member No.: 22,543 Region Association: North East States |
My brother and I picked up a couple rollers and have started our builds. The plan is to put supercharged Hayabusa engines in them, upgrade the suspension and brakes and get them on the road (safely) before working on anything cosmetic.
We picked them up from Keith down in Nepoleon, OH and he recommended I document the build here. My brother is working now on the fab for the engine cradle and sourcing the transfer case to drive the rear axles. My job at present is to beef up the suspension and brakes to handle the planned 300+HP. Mine is the black 74 which will probably end up with steel GT flares. My brother's is the primed and glassed out 72. Let the fun begin! (If anyone has 5-lug / brake upgrade parts available, please PM me) Attached thumbnail(s) |
roblav1 |
Oct 7 2019, 01:47 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I built SCCA formula cars with M/C engines and thought about doing the same in a 914.
Dump the 914 transaxle and rear suspension. Build out a tube frame structure attached at the firewall corners. Make a box out of 3/8 aluminum plate. Attach that box to the engine mount throughbolts. Get a limited slip diff for MC conversions. Run a-arms from that box to the uprights. The diff goes inside that box I mentioned. Slot that box at the diff mounts to move diff for chain tension. I have pictures of my formula cars if needed. You'll need different rear uprights. A 928 rear uprights can be made to work. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:26 AM |
